Notices
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
2004 GTO for sale **clean and built**
Old 11-19-2016, 09:35 AM
slammin86's Avatar
Default 2004 GTO for sale **clean and built**
Year: 2004
Make: Pontiac
Model: GTO
Price: $20999
Mileage: 72000
Location (State): MO
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
PRICE DROP $20,999
Tons more pictures here!
http://springfield.craigslist.org/cto/5883433826.html
Photobucket album link here!
http://s7.photobucket.com/user/slamm...o%20for%20sale
ONE OWNER 2004 Pontiac GTO 72000 miles
Reason for selling: It's been a fun build and I have learned a lot but I'm getting old so I bought a C6Z06!
Need any other pictures needed just ask!
Motor (installed at 40,000 miles in 2009)
"Forged 347" built by eagle machine. Balanced rotating assembly. Stock crank.
Mahle pistons
Callies/ Compstar rods
Ported and shimmed LS6 oil pump
Timing Chain (don't remember brand)
ARP rod bolts
Cam- 229/234, .600/.612, 111 + 4 LSA (cam was degreed in and installed at a 107 centerline)
ARP head studs
Sakimichi dual catch can
Functional pcv system w/ 1 way pressure relief valve
Underdrive Pulley
NGK BR7 plugs
Taylor 100MM wires
Noltec poly motor mounts
Trick flow as cast 220's hand ported by Brian Tooley (powdered metal guides) (installed 2012)
GM MLS head gaskets
LS7 rockers with trunion upgrade
Fast 92/ 92 combo port matched by Brian Tooley
Svede OTRCAI 2x2 Carbon Weave (1 of 1)
SD tune
Billet tensioner
Nasty N8 fuel rails
Fuel
Lingenfelter/ walbro 255 fuel pump kit
Ford 42lb green top injectors
Drivetrain
Texas Drivetrane Performance built transmission (installed at 52,000 miles)
Monster level 3 clutch
Remote clutch bleeder located by master cylinder
GMM Ripshift street w/ LSS installed w/ cobra bob shifter gasket
DSS carbon fiber 1 pc drive shaft
DSS stubs
DSS axles
Harrop
Wavetrack
OEM 3.91's cryotreated
Rear built by TBO (installed 2014)
Exhaust
Kooks 1 ¾" headers
Kooks cattless midpipes modified to 3" all the way through
Custom (417motorsports) single 4" polished SS exhaust. Vibrant resonator and borla oval with corsa oval tip (sounds amazing).
Stock MLS header gaskets
Brakes
Wilwood drilled and slotted 14" front 12.19 rear (installed 2014)
SS lines
Line Lock
Suspension
BC coilovers (installed 2014)
Superpro strut top bushings
Superpro front and rear radius rod bushings
Full energy suspension bushing kit: Front and rear sway bar, inner and outer rear control arms, rear subframe, rear diff. (front control arm and end link bushings not installed)
Noltec camber kit installed at outer position
Rear toe rods
ARP extended wheel studs
Wheels/ Tires
VMR V710 custom powdercoated
Custom made center caps
235 40 18 RE71R (700 miles on them)
265 35 18 RE71R (700 miles on them)
Project KICS 2 pc lugnuts with locking nut
Appearance
05/06 hood w/ shaved grills
OEM Sap grills painted PBM
OEM VX Tails tinted by Jorge
Spoiler delete
Goldilocks 2.0 (some pics show the OG goldilocks this one is no longer on the car the 2.0 is!)
Tinted side marker lights
5% tint on sides and back, 35% on entire windshield
JBiz front and rear polished arrowheads
JBiz side markers
Full JBiz cap set under hood with (1 of 1) coolant cap and (1 of 2) brake cap
ARP 12 pt polished nuts/ bolts everywhere under hood and a few under the car
Whole car wetsanded
Weight Reduction
BMR light weight skid plate
Fuel tank brace delete
Tow hitch mount delete w/ TBO kit to retain rear plastic
Interior
2006 OEM gauge face overlay
Aem Uego wideband
Aeroforce scangauge
Gatorpod (looks OEM)
Custom faces for the gauges to look OEM
Holden sport steering wheel (installed 2015)
New oem shift **** and boot (installed 2015)
JBiz carpet clips
Nitrous
Nitrous outlet 92MM plate
Nitrous outlet fuel, nitrous and purge solenoid
Nitrous outlet heated bottle bracket
Nitrous outlet 15 lb bottle
Nitrous outlet nitrous filter
Nitrous outlet switch panel
NX remote opener
CUSTOM GLOVEBOX AND WIRING SETUP LOOKS AMAZING
Dynotune nitrous pressure gauge
HSW Microedge controller
Leash relay box for bottle heater
Leash nitrous controller with 2step disarm
Leash fuse panel
Schematic for all electronics added in car with color code!
Stereo
Pioneer AVIC X710BT
Team SCSS install kit (looks OEM)
Steering wheel interface
Infinity Kappa component set
Misc
Tuned by me since 2009
LPE 2 step w/ no lift shift
OEM Shift light activated
Rev limiter set at 7400
Daytime running lights disabled
Optima red top
Car cover
Service manuals
The good
I bought this car new off the showroom floor in October 2004
Never drove in snow/ never seen salt
Meticulously maintained and cared for and mostly documented on LS1GTO.
All of the above mods to the car were done and installed by me with the exception of the motor build, transmission build, rear end build and exhaust. Heads and intake were installed by me.
Interior in great shape
Underhood is amazing
Undercar is amazing
The bad
Area on front bumper where a pterodactyl flew into the front of the car at hwy speed and spider cracked the paint on the bumper. This area is about 2" tall by 8" long and really is not that noticeable.
The Other
If I had to rate this car on a scale of 1 to 10 (10 being best)
Exterior 9
Interior 9
This car is in amazing shape considering it is a 12 year old car
Car made 440/410 in mid july 2014.
Car made 620/625 same day on a 200 shot running rich.
The trap speeds tell the story of what this car is capable of. Dyno numbers mean nothing.
Car has ran a best of 10.99 and trapped a best of 135 on a 163 shot
Car has ran a best of 11.7 and trapped 122 on motor
This car has drove to the track, made 10+ runs at a time and drove home under its own power without problem time and time again. The car has only been on a trailer 3 times since I bought new in 2004.
I can answer text messages most of the time and text is the preferred method of contact.
If you're out of state I can pick you up at the airport. I can also help arrange shipping. I would consider taking some parts off of the car and selling it for less as well but I would need some cash upfront before pulling anything off of it.
Attached Thumbnails 2004 GTO for sale **clean and built**-15133736_10154277837223732_1239644056_o.jpg   2004 GTO for sale **clean and built**-10-clean-gtos.jpg   2004 GTO for sale **clean and built**-15133651_10154277815978732_181058017_o.jpg   2004 GTO for sale **clean and built**-15127512_10154277816088732_472771425_o.jpg   2004 GTO for sale **clean and built**-15133769_10154277816133732_1107473979_o.jpg
2004 GTO for sale **clean and built**-15134039_10154277816028732_252912182_o.jpg   2004 GTO for sale **clean and built**-20150207_170351.jpg   2004 GTO for sale **clean and built**-20150315_134407.jpg
Old 11-19-2016, 09:46 AM
2002Firehawk's Avatar
From one 04 owner to another - great looking car and awesome build. Free bump and GLWS!
Old 11-19-2016, 06:34 PM
JDEP162's Avatar
Dam. I'm only a window ahopper, but I'd kill to hear a clip of this running. free bump.
Old 11-21-2016, 03:14 PM
NovaCain383's Avatar
Very tempting as bad as I want to get in another GTO.
Old 11-21-2016, 06:45 PM
slammin86's Avatar
LMK if you guys have any questions.
Here is a link to my youtube page. There is a very sarcastic walk around video also...!
https://www.youtube.com/channel/UCEV...x2sd_6sr5LKEtw
Old 11-25-2016, 01:02 PM
slammin86's Avatar
Black friday sale going on now!
Old 12-14-2016, 05:41 PM
slammin86's Avatar
It is a shame no one feels these cars are worth over 10K.
Old 12-18-2016, 08:41 PM
Z28-4-Chris's Avatar
i feel ya, I sold my 04 back in 2013 for 13k and I felt like they got a great deal.
https://ls1tech.com/forums/vehicle-c...st-brembo.html
Old 02-25-2017, 07:19 AM
slammin86's Avatar
Let's bring this one back up. It is still sitting in the garage under a car cover where it has been for months.
Let's deal and get this thing sold!
Old 02-25-2017, 07:20 AM
slammin86's Avatar
https://ls1tech.com/forums/nitrous-o...ll-thread.html
Old 03-18-2017, 04:44 PM
slammin86's Avatar
Lowered price. Make offer.
Old 03-22-2017, 01:55 PM
House will be done soon. Would like to get in another GTO.
Old 03-22-2017, 05:47 PM
slammin86's Avatar
This one would be a great one to do it with!
Old 03-26-2017, 10:22 AM
slammin86's Avatar
I found something to do with the money. I'd love to move this by the end of next month.
Old 04-10-2017, 08:45 PM
mrsmith2368's Avatar
Contact # ? Interested
Old 04-10-2017, 11:33 PM
Wildcobra's Avatar
Clean Gto a little out of my price range
Old 04-29-2017, 07:40 AM
Any updates on this?
Old 05-25-2017, 07:23 AM
Chuck Brigham's Avatar
PM sent.
Quick Reply: 2004 GTO for sale **clean and built**
