Notices
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
1992 LS1-T56 Swapped Camaro
Old 10-12-2016, 11:55 AM
yellowzcar's Avatar
Default 1992 LS1-T56 Swapped Camaro
Year: 1992
Make: Chevrolet
Model: Camaro
Price: $8250
Mileage: 262000
Location (State): PA
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
1992 RS 25th Anniversary Edition Camaro that has had a LS1 – T56 swap done. Flemings Ultimate Garage of Rockville MD did the swap in 2005. I am the third owner since the swap was completed, and have the original paperwork from Flemings documenting the swap as well as the work done by the second owner. I have done significant suspension upgrades, as well as general maintenance since buying the car in 2011, all of which is also documented. I am selling due my lack of available time to drive the car.
PRICE: 8,250 OBO - Open to Offers
MOTOR & DRIVETRAIN
-99 ls1 (stock internally)
-GTO K&N Intake
-True duels over the axel off manifolds, through bullets and cats
-T56 trans
-4th gen 10 bolt with 4:11's
-Alum driveshaft
-Walbro 255
-Fuel Pressure Regulator
-Line Lock
SUSP & CHASSIS
-36/24 swaybars
-Poly bushings
-Rod/poly founders LCA's
-S&W Poly on car adj Panhard Bar
-Koni yellows all around
-Ebaich pro spring kit
-Founders solid bearing strut mounts
-New Moog Steering components, ball joints, ext.
-UMI tie rod adjusters
-Timken wheel bearings all around
-K member notched for AC, AC uninstalled.
WHEEL TIRES BRAKES
-OE wheels repo c6 base wheels 18”x9.5”
-2in alum spacers up front
-245/35/18 riken raptors with half tread left.
-Stock front brakes with drilled rotors
-Stock 97 4th gen rear brakes
INTERIOR
-B&M short throw shifter
-Custom seats and door panels
-Replacement black carpet
-Head unit – Pioneer
-3a Racing Seats
-Harnesses
-Dynamat – Doors, floor, trunk
Car weighs 3280 without me in it, 1/4 tank of gas
ISSUES
Driver Window Motor bad – new part is Included
Front lip was slightly scraped
Driver side T top has a chip in the paint
Passenger side cat bad and rattles
Chip in paint of wheel centercap
Dash speakers are bad
Small patch on driver side rear wheel well due to 1/2” x 6” hole
Small rust spot driver side floor pan
Small rust patch passenger side rear wheel well
Large rust patch under rear bumper
Speedometer reads half of true RPM
PHOTOS:http://s1278.photobucket.com/user/ye...?sort=3&page=1
CONTACT: PM, Text, Call, 610-716-8794 (I wont answer between the hours of 6am-9pm est. during the week as I work those hours)
Attached Thumbnails 1992 LS1-T56 Swapped Camaro-img_2405.jpg   1992 LS1-T56 Swapped Camaro-img_2406.jpg   1992 LS1-T56 Swapped Camaro-img_2407.jpg   1992 LS1-T56 Swapped Camaro-img_2429.jpg   1992 LS1-T56 Swapped Camaro-img_2432.jpg
1992 LS1-T56 Swapped Camaro-img_2431-1-.jpg   1992 LS1-T56 Swapped Camaro-img001.jpg   1992 LS1-T56 Swapped Camaro-img002.jpg   1992 LS1-T56 Swapped Camaro-img003.jpg
Old 10-12-2016, 01:23 PM
Stew2000's Avatar
bad *** car
Old 10-13-2016, 01:02 PM
yellowzcar's Avatar
Thanks!
Old 10-20-2016, 07:25 AM
yellowzcar's Avatar
Bumpp
Old 10-20-2016, 08:01 AM
static low 92's Avatar
Paper work states "install used LS2 motor"
You say its an LS1. Very big difference there. Can you verify one or the other?
Old 10-21-2016, 08:11 PM
kevin99hoss's Avatar
3rd gen bump
Old 11-06-2016, 07:24 AM
yellowzcar's Avatar
You are correct that the paperwork states that, it must be a typo, as the block and head casting numbers show it is an LS1.
Thanks for the Bump!
Old 03-21-2017, 06:10 PM
yellowzcar's Avatar
Bumpp
Old 03-24-2017, 09:04 AM
stealthram92z's Avatar
Beautiful 92, this is a steal, If I didn't have 2 of them I'd be all over this, GLWS
Old 03-26-2017, 10:21 AM
yellowzcar's Avatar
I appreciate the compliment and best wishes! Great to see so many third gen guys on this site.
Old 04-02-2017, 08:24 AM
yellowzcar's Avatar
bumpp
Old 04-18-2017, 05:36 PM
yellowzcar's Avatar
bumpp
Old 04-28-2017, 07:06 AM
yellowzcar's Avatar
Bumpp
Old 05-02-2017, 05:51 PM
yellowzcar's Avatar
Bumpp
Old 05-09-2017, 06:48 AM
yellowzcar's Avatar
Bumpp
Old 05-25-2017, 07:12 AM
yellowzcar's Avatar
Bumpp
Old 06-11-2017, 08:15 AM
yellowzcar's Avatar
bump, open to offers
Old 06-24-2017, 09:17 AM
yellowzcar's Avatar
bumpp
Old 07-01-2017, 02:20 PM
JonnyiDFW's Avatar
Any Under Hood Pics? I clicked on your link to pics, but it would not pull up?
thanks
Old 07-22-2017, 03:34 PM
mikesanto70's Avatar
Flemings really put a 10"' right up the 1st owners rear tail pipe..... $15k....wheeeew....
Quick Reply: 1992 LS1-T56 Swapped Camaro
