turbo car part out
turbo car part out
Category: Accessories
Price: $1000000
Location (State): MI
Item Condition: Used
LS Engine?: Fits LS Engine
Bright Blue Metallic roller. Car has motor plate, stock rear and front suspension also stock rear end. No hood Car has all the stock wiring besides pcm. Car is super clean and had low miles. 2000$
Quick Performance Rear end. 35 spline axels. Big ford ends. Spool. Torque arm mount. Nodular center section. Also has wilwood brakes. Will not seperate 2000$
Th400 RMVB with Hipster trans brake. Has maybe 5 passes and 50 street miles on it. Built by kenny lang. 1000$
Precision Turbo large frame 88mm x275 turbo. Very little run time on it. Came off of a well known car in Chicago. 2500$
Hotside and partial coldside for t6 turbo. Aluminum cold side, no intercooler. Forward facing truck headers. 1500$
Sold-ly6 6.0 short block. all new rings and bearings. Ls3 heads and ls1 oil pan. No intake. Has valve covers, valley cover, ls9 head gaskets. Ls7 lifters. 7.4 brian tooley push rods. Knock off head studs. Also has brian tooley valve springs.
Turbo cam spec'd from tick performance(martin smallwood) for 88m turbo and ly6. 250$ would like motor and turbo to sell before this.
Sold-98-02 camaro sumped steel fuel tank
Will be adding more as things sell. Serious inquiries only please.
Text me at 313 585 1735 for pics. Do not ask for pics unless seriously interested.
sumped tank
Can you tell me more about the sumped?
UOTE=GrnGoblin;19131567]Parting out a turbo car i had intention on building but would rather buy a complete car. All parts are located in metro Detroit Michigan and dont plan on Shipping anything large.
Quick Performance Rear end. 35 spline axels. Big ford ends. Spool. Torque arm mount. Nodular center section. 2000$
Ly6 6.0 short block. all new rings and bearings. Ls3 heads and ls1 oil pan. No intake. Has valve covers, valley cover, ls9 head gaskets. Ls7 lifters. 7.4 brian tooley push rods. Knock off head studs. Also has brian tooley valve springs and 2000$
98-02 camaro sumped steel fuel tank 250$
Thanks[/QUOTE]
Thanks[/QUOTE]
