Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
9" rear end housing and axles Trick Chassis
Old 01-26-2016, 09:35 PM
TrickChassis's Avatar
Default 9" rear end housing and axles Trick Chassis
Category: Accessories
Price: $1140
Location (State): WI
Item Condition: Brand New
LS Engine?: Fits LS Engine
Trick Chassis 9" Rear ends for 3rd or 4th gen Camaro and Firebird 1993 to 2002
FILL AND DRAIN (STANDARD)
Brand new center housing can (STANDARD)
4 lower control arm mounting holes (STANDARD)
3" .250 wall axle tubes (STANDARD)
Internal axle tube gussets (STANDARD)
Fits aftermarket torque arm's
Torque arm bracket is included
Your choice 31 or 35 spline STRANGE ENGINEERING axles wheel studs and bearing
LS1 OR LT1 stock brakes will fit!
All the above is $1140
We also sell center sections!!
This can be a fully assembled unit
Brake lines
Powdercoating
E brake
ABS 4 channel available
5/8" stud up grade
Gun drilled axles
40 spline axle's available
Back bracing available
Anti roll bar setups
Aftermarket brakes
Message me or post your questions
Shop phone number 608-313-9197
Info@trickchassis.com
Check them out on the website
Trick Chassis 9" setups
Attached Thumbnails 9" rear end housing and axles  Trick Chassis-rearend-1.jpg   9" rear end housing and axles  Trick Chassis-img_6817.jpg   9" rear end housing and axles  Trick Chassis-rearend-2.jpg
Old 01-26-2016, 09:55 PM
joedirt98ls1's Avatar
is that 1140 shipped
Old 01-27-2016, 06:23 AM
Shipping is not included for the price of $1140
Send me your zip and i can get a quote. The housing and axles are shipped UPS ground.
Old 01-27-2016, 07:43 AM
LE35TH's Avatar
Is this a sale price? I will be getting a 9" but it will be a little while.
Old 01-27-2016, 08:32 AM
Old 01-27-2016, 10:05 AM
We will not have a sale on these. This price is as low as we can go with all the extra options that come standard.
Old 01-27-2016, 10:17 AM
Spectre86's Avatar
welcome. didn't know you guys were a sponser.
Old 01-27-2016, 05:08 PM
Thanks!!
Old 01-27-2016, 07:03 PM
jblankenship's Avatar
Mine fit great. Back braced, 35 spline, stock width, 5/8 studs, Strange actually dual drilled the flanges for 5/8 studs and stock .509 knurl. My rear was nearly dead centered when swapping in the new rear from the stock unit that was centered previously. Same deal on front to back location. It did come with the center section studs already pressed in, however just for myself I swapped to ARP. There was nothing wrong with the studs in it and he was straight foward that they were Dorman brand. I did also add T-bolts to the order. The swaybar mounts are included as well and on the money compared to stock spacing. I did add 2 tabs for the hard brake lines and welded one nut for the brake line bracket. Here is my thread, I need some updated installed pics: https://ls1tech.com/forums/gears-axl...y-got-9-a.html
The gentlemen that runs the company was exceptional to deal with. Always answered the phone and was pleasant answering questions. Very nice piece. Great packaging and turn around time. I would absolutely deal with this company again.
Old 01-27-2016, 07:26 PM
LE35TH's Avatar
I was making sure this wasn't a sale price because its a great price. I be giving yall a call when I'm ready to order.
Old 01-27-2016, 07:32 PM
Sounds great!!
We can also make shortened 9" setups also!
Old 01-28-2016, 08:15 AM
Rise of the Phoenix's Avatar
So a center section is really all that's needed to complete the rear end, correct? I assume you can use your existing brake lines if you choose to?
Old 01-28-2016, 08:19 AM
Yes correct. Center section which i can provide and some do use there stock hard line brake lines.
Center sections Trick Chassis
Old 01-28-2016, 08:34 AM
brobinson216's Avatar
Drive shaft will require to be shortened as well.
Old 01-28-2016, 10:37 AM
Drive shaft will need to be longer if anything. Unless you use a long yoke on the 9 inch 3rd member.
Old 01-28-2016, 11:29 AM
Correct if using a PG/TB400 longer.
6 speed will require shorter.
Either way will require modification to driveshaft. Not trying to Discourage anyone, rather just educating on what is required to make the changeover as painless as possible.
Old 01-28-2016, 02:37 PM
Why would a manual transmission take a shorter driveshaft when the 4l60e and manual use the same shaft and a 4l60e I know needs a longer shaft by one inch.
Old 01-28-2016, 02:46 PM
My car with 6 speed / 9in required 1.5" shorter.
Old 01-31-2016, 07:03 AM
A quality driveshaft and trans yolk is highly recommended. We can get you this from Strange Engineering to complete your 9" install.
Old 01-31-2016, 11:08 AM
72Elkytpi's Avatar
Can you pm me a shipped price with center section. 31 spline limited slip type setup that can handle at most 700hp. I'm in Florida 32751.
Richard
Quick Reply: 9" rear end housing and axles Trick Chassis
