Camaro SS turbo 800rwhp trade
Year: 1999
Make: Chevrolet
Model: Camaro
Price: $20000
Mileage: 95000
Location (State): OH
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
It is currently turbocharged making over 800rwhp (18.6lbs, 632/500 on 10.6lbs), and was tuned by Brian Turner @ Dynotune Motorsports for E85 only. Transmission is stock but shifts smooth. Sitting on ZR1 17x9F and 17x11R. There is no radio or AC. Heat is still there and works well. Has some minor paint scratches and small dents. Front bumper cutout for intercooler. Innovate SCG-1 Electronic boost controller/wideband.
Would Trade for C5Z, C6, CTS-V, G8 GT/GXP, E55 AMG
or an 06+ Duramax. Maybe a Cummins
Motor:
LR4 4.8L
ARP Head studs
Patriot Dual Valve Springs w/Ti Retainers
COMP Hardened Pushrods
LS7 Lifters
Melling Stock Volume/Pressure Oil Pump
Tick Stage 2 turbo camshaft
LS6 intake manifold
AGP 46mm Wastegate
HKS Race style BOV
F.I. 91/83 hybrid turbo rated for 1400
3" intercooler w/all 3" piping
FAST 3 bar map sensor ***SD tuned
Truck manifolds flipped forward
Fuel:
-10AN Feed with stock line used as return
Aeromotive Boost referenced fuel pressure regulator
Holley fuel rails
Bosch 160lb injectors
Twin 255lph fuel pumps in the tank
Jegs -10 inline filter with stainless element (for e85)
Drivetrain:
Stock T56 Transmission (still shifts perfect)
Pro 5.0 Shifter
CAGS skip shift eliminator
Mcleod Twin disc RST clutch
SPEC aluminum Flywheel with removable steel insert
MOSER 12 Bolt Rear with 31 spline axles w/Eaton Posi
SJM ABS delete with line lock kit
Chassis:
Jegs 2pt bolt in subframe connectors
UMI tunnel mount torque arm w/DSSL
UMI on-car adjustable panhard
Hotchkis rear LCA
Have more pics. Just pm me.
