Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
NEW PRC 6 Bolt 260cc CNC LS3/LSA/LS9 Port And High Ram
Old 11-05-2016, 08:34 AM
yoshgixxer's Avatar
Default NEW PRC 6 Bolt 260cc CNC LS3/LSA/LS9 Port And High Ram
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): PA
Item Condition: Brand New
LS Engine?: Fits LS Engine
Everything is brand new except rockers!! Only trades I'm looking for would be C5 Turbo kit. Or C6Z rear end and maybe a TR6060
410-218-1620
SOLDDDD PENDING DEAL
! Complete LS3 top end swap!
PRC 260cc LS3 square port cylinder heads, .750" thick deck for big power, 6 bolt head provision (still fits 4 bolt block) CNC runners and 65cc chambers. Stainless valves with titanium hardware, PAC .660 lift dual springs. Brand new in the box as they came from Texas speed. Flow over .385 CFM!!!
Micro Polished and heat treated LS3 Rocker arms with trunion upgrade and 12 point grade 10.9 bolt upgrade
Box stock LS3 Holley High Ram, 105mm mouth. Smoothed and powder coated black lid. Holley black fuel rails and stud kit.
Head specs
PRC's aftermarket casting LS3/L92/L99 cylinder heads come standard with the following options:
NEW PRC 13-Degree Valve Angle LS3 Castings
Improved Piston-to-Valve Clearance For Extra Compression & Larger Camshafts
Smaller Than Stock Intake Port Volume For Improved Port Velocity
Manley Stainless 2.185" Intake, 1.60" Exhaust Valves
Billet Rocker Pedestals
TSP .660" Dual Spring Kit w/ PAC Valve Springs, Titanium Retainers, Seats, & Seals
Completely Assembled and Milled to Your Specifications
60-68cc Chambers
All PRC cylinder heads are extensively researched and tested. The all-new PRC aftermarket casting LS3 cylinder heads are designed to flow considerably more than a gm ported casting while keeping the port sizes smaller for improved port velocity. The result is a cylinder head that is smaller than a stock GM LS3 port and moves more air than any other ls3 cylinder heads!
The all new PRC aftermarket casting LS3 heads are the perfect option for customers looking for the ultimate in LS3/L99/L92 cylinder head technology
The PRC aftermarket casting LS3 cylinder heads are available in 2 different configurations:
260cc Runners For stroker engines needing a 380cfm+ cylinder head!
The 13-degree valve angle will allow for the ability to run more compression and larger camshafts thanks to additional piston-to-valve clearance!!
Lift
Intake Flow
Exhaust Flow
.200" 157 cfm117 cfm
.300" 224 cfm170 cfm
.400" 279 cfm205 cfm
.500"329 cfm 225 cfm
.600"360 cfm 235 cfm
.650" 372 cfm 240 cfm
.700 380 cfm 243 cfm
Attached Thumbnails NEW PRC 6 Bolt 260cc CNC LS3/LSA/LS9 Port And High Ram-image.jpeg
yoshgixxer's Avatar
Intake,rails and hardware
Old 11-05-2016, 08:35 AM
yoshgixxer's Avatar
Runners
yoshgixxer's Avatar
65cc chambers
Old 11-05-2016, 08:36 AM
yoshgixxer's Avatar
CNC rocker stands
yoshgixxer's Avatar
Trunion upgrade rockers, upgrade rocker bolts, heat treated and micro polished by RPM
Old 11-09-2016, 08:20 PM
Helomedic1171's Avatar
do you have an LS3 cam?
Old 11-10-2016, 12:32 PM
yoshgixxer's Avatar
No sorry everything I had LS3 is now sold
Quick Reply: NEW PRC 6 Bolt 260cc CNC LS3/LSA/LS9 Port And High Ram
