Who carries polyurethane motor mounts?
Old Nov 22, 2003 | 07:14 AM
Larry's Avatar
Default Who carries polyurethane motor mounts?
I have checked several sponsor web sites for polyurethane motor mounts without any luck. Who carries mounts and what brands are available?
Old Nov 22, 2003 | 07:30 AM
SpohnPerformance's Avatar
LS1TECH Sponsor
We carry them (Prothane), I don't think I have them on the website yet, just call to order. They are $39.00/pr.
Steve
Old Nov 22, 2003 | 02:59 PM
2001CamaroGuy's Avatar
I got my set from Jegs, Summit also has them, and I'm sure a number of the sponsors sell them.
The only "problem" is that you only get the "inside" part (the poly) and you have to cut apart a factory motor mount to install the poly.
I bought another set from a guy, cut them apart, had the metal parts (the clams) powder coated, and then bolted them back together (with the new poly inside) with stainless bolts and metal center locking nuts. By doing this, I have better motor mount (won't rust) and was able to pay $50 to have someone else beat their hands up swapping the mounts (well worth the cost).
Old Nov 22, 2003 | 09:12 PM
Larry's Avatar
Sounds like I better crawl under there and take a better look at what I'm up against. Might be more work than I originally thought. Just trying to keep my Y pipe from rubbing on that drivers side.
Old Nov 22, 2003 | 09:16 PM
I would take a look at it.......I have a BMR K-member (so its about 500% easier to get at things) and I still don't like messing with motor mounts
as I said, get a set (used) from someone, mod them, and then take the car to a shop and pay them $50 - $100 to swap them out.....it is WELL worth the money
Old Nov 22, 2003 | 09:20 PM
Larry's Avatar
I have a tubular K member also but did not remove the motor mounts to install it. I have examined the mounts but not the part about cutting the clams to get it apart. Thanks!
Old Nov 22, 2003 | 09:32 PM
the clams are rivited together....so you must mount them in a vice and drill out the rivits.....thats the easy part
Old Nov 22, 2003 | 11:23 PM
WILWAXU's Avatar
Larry.. I think it will be an even easier swap with your K member.. since you can remove the whole motor mount if nesasary.
As far as the swapping out of the bushings... it's pretty straight forward. You'll need a good sharp chisel, drill and a good vise. Alot like swapping to a poly tranny mount... just a little more of it. Not a bad idea to have some paint handy to "touch" them up afterward.
Old Nov 23, 2003 | 09:09 AM
Larry's Avatar
As far as the swapping out of the bushings... it's pretty straight forward. You'll need a good sharp punch, drill and a good vise. Alot like swapping to a poly tranny mount... just a little more of it. Not a bad idea to have some paint handy to "touch" them up afterward.
I bet I can handle that. Thanks!
Old Nov 23, 2003 | 11:10 AM
motor mount swap is well below a head/cam swap on the "how hard is it" list.......I just felt it was really tedious and didn't want to play with it myself
Old Nov 23, 2003 | 09:26 PM
WS6FirebirdTA00's Avatar
when i did my torque arm bushing i just took a sharp chissel to it and hitit 2 times and the rivet broke....
Old Nov 24, 2003 | 11:01 AM
WILWAXU's Avatar
Yeah.. I meant chisel not punch.. fixed it above.
