FS: 9" T-56 Pro stars iron block 6.0 crank
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
Mosier housing purchased from Billingsley racing a few years back, stock length
35 spline axles
fill plug added on the back of the housing for easy oil fills
strange spool
strange nodular iron 3rd member
Richmond 4.57 pro gears
5/8 wheel studs
modified lca drop brackets for very low cars
4 channel backing plates with reluctor wheels installed on axles.
Wofle single adj anti roll bar installed on rear end (all you need are the mounting tabs for the body)
Gears and spool have about 30 passes on them
Rear end will be sold complete minus the cast torque arm mount, you will need to purchase a new one as mine is made to my torque arm.
SOLD
T56 with pro 5.0 shifter and mcleod bell housing.
Viper main shaft
Viper input shaft
Billet 3/4 keys
Steel 3/4 fork
Bronze fork pads on all forks
all sliders and syncros have been replaced
Trans shifts smooth and easy with no grinding howling or any other noises.
SOLD
3" dia drive shaft with 1350 series u joints on both ends and viper yolk. Built for a f-body with a viper spec t-56 and 9" rear.
SOLD
![](http://img.photobucket.com/albums/v294/SpeedyWS6/wheels15x10001.jpg)
![](http://img.photobucket.com/albums/v294/SpeedyWS6/wheels15x10002.jpg)
15x10 pro stars 7.5 bs with 29.5x10.5 stiff wall mickey thompson tires mounted on them. Wheels are drilled for rim screws and in great condition. Tires are 1/2 worn.
$450
6.0 iron block and crank, I purchased from a member here and I have done nothing with it
$450
35 spline axles
strange spool
5/8 wheel studs
SOLD
Viper main shaft
Viper input shaft
Billet 3/4 keys
Steel 3/4 fork
SOLD
SOLD
$450
$450
