*HUGE Performance & Stock Part Out Sale* HKE Shortblock, Greg Good Heads, & MUCH More
Below is a list of the available parts for sale. If you do not see what you're looking for, I do not have it. Please do not ask me about parts not listed below.
Condition of parts: If there's an asterik (*) next to the part, it means that it's practically new with only (10) 1/4 mile passes on it. The rest of the parts are in excellent/new like condition.
Feedback: I have 100% positive feedback here on the board and on Ebay (i8asvt), with a combined score count of 188.
Payment: I accept Paypal, money orders, cashier's checks, Western Union, Moneygram, etc., with Paypal being the preferred payment. If you choose to use Paypal for payment, you must send as an instant transfer or an e-Check. No credit card payments. You must select the Personal tab and choose Payment owed or Other for "This money is being sent as a:". If you choose the Purchase tab, then 2.9% + $.30 will be deducted from the money I received and I will not be responsible for those fees. If you wish to choose the purchase tab, then you will need to add the 2.9% + $.30 fee to the amount owed on the purchased item(s).
Shipping: Prices do not include shipping unless specified.
Prices: No low balling, trades, bashing, and please, do not reference prices to Ebay. If you have any comments, opinions, or suggestions, please PM me. There's no need for a discussion, debate, or war on my parts for sale. So please, let's keep this clean.
Engine:
*GM LS3/L92 Aluminum Block
*Callies Dragonslayer 4” Stroke Crankshaft
*Callies Connecting Rods
*Wiseco Custom 9.6cc Dome Pistons
*Wiseco Custom Pins
*Wiseco GF Piston Rings
*Federal Mogul Main Bearings
*Federal Mogul Cam Bearings
*ACL HB Coated Rod Bearings
*ARP Main Stud Kit
*ARP 2000 Series Rod Bolts
416 CI
Shortblock: Block honed, line honed, deck set with pistons, balanced, and assembled by Erik Koenig of HKE Racing Engines - $4,925
Cylinder Heads/Valvetrain:
*Greg Good Fully Ported/Polished LS3/L92 Cylinder Heads (New Castings) w/Xceldyne Titanium Intake Valves, Ferrea Hollow Stem Exhaust Valves, Custom Spring Seats, Patriot Gold Extreme Dual Spring Kit, & 67cc Combustion Chambers - $2975
*Manton Restricted Pushrods - $170
Intake:
Fast Toys Ram Air Block-Off Plate -
Forced Induction:
Procharger Open Race Bypass Valve - $325
Exhaust:
Kooks 3"x3" Stainless Steel Catted X-Pipe ('97-'09 Corvette) - $600
Ignition/Electrical:
O2 Extensions (1) 12" (1) 24" - $20 each
Drivetrain/Transmission:
Protorque Torque Converter (TH350) - $850
Suspension & Chassis:
Wolfe Racecraft Sway/Anti-Roll Drag Bar (Black) - $300
Interior & Safety:
*Autometer Ultimate II Tachometer $525
Wheels & Tires:
*Hoosier Radial Slicks 30x10.5x15 - $390
McGard Front & Rear Lugnuts - $85
Bogart Center Caps -
(1) 275/35/18 Dunlop SP Sport 01 (25% left) - $20
Stock Parts:
A/C Condenser - $100 shipped
HVAC Ducting (for vents) - $20 shipped
Brake Master Cylinder - $80 shipped
Brake Booster - $100 shipped
Rear Brake Rotors - $50 shipped
Rear Brake Hoses - $35 shipped
Front Brake Hoses -
Brake Lines (engine bay area) -
Wheel Hubs w/Speed Sensors - $200
Air Pump Bracket - $15 shipped
Lifters - $60 shipped
Intake & Exhaust Valves -
Monsoon Amp - $80 shipped
Triangle Hold Downs (hatch area) -
Passenger Airbag Bracket - $15 shipped
Rear End/Swaybar U-Bolts/Brackets -
Panhard Bar - $30 shipped
Upper A-Arms - $70 shipped
Upper A-Arm Mounts -
Spindles - $200
Rear Swaybar Bushing Bracket -
Wiper Motor/Linkage - $90 shipped
Wiper Arm Covers -
Rear Bumper Support - $75 shipped
Front Air Dam/Spoiler -
*Rear Cover Gasket - $20
*Timing Cover Gasket - $20
Oil Pan Gasket - $30
Motor Mounts -
Fuel Hoses/Lines (engine bay area) -
Brake Booster Hose w/Fitting -
Fuel Purge Solenoid - $15
Napa Belt 76" 6 Rib -
Napa Belt 37.8" 4 Rib -
Air Lid Seal -
Engine:
*Wiseco Custom Pins
*ARP Main Stud Kit
416 CI
Intake:
Forced Induction:
Exhaust:
Interior & Safety:
Wheels & Tires:
Stock Parts:
Front Brake Hoses -
Spindles - $200
Wiper Arm Covers -
Motor Mounts -
Air Lid Seal -
It's the black air deflector under the car. There are so many different things that it's called, but I used Air Dam/Spoiler for the description. A lot of parts are interchangeable between the Camaro and Firebird, but those that are not came off a 2000 Camaro SS.
There is only 1 Corvette specific part listed.
You can view the tach here:
http://www.summitracing.com/parts/ATM-6884/
Might as well call it new because it was in the car for a few passes.
