98 Z28 9sec Street/Drag/Grudge Car
Year: 1998
Make: Chevrolet
Model: Camaro
Price: $15500
Mileage: 54000
Location (State): IA
Color: Silver
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Sept 10th 2011
http://www.streetfire.net/video/sept...ot_2317069.htm
98 Z28Camaro 54K FLAWLESS COND inside and out, 9.85 of 10 cond. Always stored in climate controlled shop, Never seen rain/snow etc, looks NEW
Motor: 347 cu in LS1, Oliver Rods, Ross N20 pistons, stock race prepped LS1 crank. Comp custom grind N20 camshaft, Howards valve springs, Comp retainers, TrickFlow push rods, Harland prepped stock rockers. TEA StageIII CNC 5.3 cylinder heads,stainless valves, ported oil pump, 160* thermostat car runs cool in 100 degree weather, ARP main studs, ARP head bolts, FAST 92/92, SFI underdriven pulley, MSD big wires, Hooker headers with X-pipe and bullet mufflers,with turndowns before the rear end, SLP lid with K&N filter, Speed Density Tuned by the best "Speed Inc". in Illinois, Have the dyno sheets.
Trans: Fountain Built Reverse pattern TH350, with all the best parts, PTC 8" custom built N20, 4500 stall converter, Pro Trans brake, with Linginfelter 001 box for 2 step, Hurst quarter stick shifter, Autometer trans temp guage, deep alum. trans pan. Billet yoke. SLP linelock, Denny's N20 driveshaft
Suspension: ALL TUBULAR. AJE K-Member, Spohn upper/lower A-arms, Spohn panhard bar, Spohn lower controll arms with brackets, Random Technologys Torque arm, Wolf Racecraft anti-roll bar, Spohn driveshaft loop, Spohn round subframe connectors. Dennys N20 driveshaft. QA1 12 way adj front coilovers, QA1 12 way adj. rear shocks with V6 springs. Suspension was set up by Terry Miller Race cars, car was scaled and weight moved accordingly, Its done right! This suspension WORKS!!!!! awsome.
Brakes: Aerospace fronts, Stock rears.
Rearend: Moser 12bolt with billet cover, Moser axles 4.10 ratio, billet yoke
Fuel system: Racetronics in tank with Hot wire kit, 42lb injectors. Autometer F/P guage
Nitrous: N20 Daves 92mm T/B plate, NOS BIG SHOT bottom feed solenoids, 6an feed line, Autometer N20 pressure guage, WOT activated, Timming Tunner box for adj. retard. HSW standalone fuel system for N20, 10lb bottle mounted in rear w/10an blow down
Wheels/Ties: 15x3.5 Weld Draglight fronts with Moroso DS2 front runners. 15x10 Weld Draglight rears with 28x10.5x15s Mickey stiffsidewall slicks.
Interior: Complete stock appearing with back seat, 2 kirkey Racing front seats with covers, Simpson Harness, NO AC/HEAT/cruise/air bags etc, has power windows/locks/ AM-FM CD, tilt, all lights and other options work etc. Harlan adj.shift light, Grant steering wheel, 6 point Wolf RaceCraft bolt in cage, this car is not hacked up everything done correctly. 3' Harwood cowl hood, fire extinguisher mounted on roll bar. Battery re-located to rear w/ Flaming River PUSH/PULL Kill shut off switch
Air/Fuel monitor: AEM wide band with guage mounted in dash
This is a AWSOME FLAWLESS Street/Drag/Grudge car. It is not a shoulda run this and that car, it runs the #s and I will and can prove it, If you are a serious buyer I will bring it to Cordova/Byron/Cedar Falls Raceway and run the car for you, First weekend out this year 9.82@135.5mph with 1.34 60' off the footbrake shifting into 2nd in the air, with a 150shot, has plenty left in it, runs 10.60-10.70s N/A, weighs 3169 w/o driver, I have videos, and time slips, this car looks stock under the hood with a N20 kit, nothing fancy, I feel this car has 9.70s in it the way it sits.. ( UPDATE 9/3/2011...9.73@138) ABSOLUTLEY NO DISSAPOINTMENTS. You will NOT!!! Find one nicer for the money, Car leaves straight as an arrow wheels up every pass, I am sure I am forgetting things and will ad as I remember...lol $16,000 FIRM!!!! Will not sell as roller, may consider partial trades, We currently have 2 F-Bodys and can only find time to race 1, Have tons of photos and videos avail. I am sure I have forgotten some things but you get the basic idea. Please feel free to PM me with any questions. I will post more detailed photos tonight. Thanx.
