F-Body Drilled and Slotted Rotors AND Brake Pad SPECIAL!!!
BRAKE SPECIAL!!! Front & Rear Zinc Plated Drilled and Slotted Brake Discs/Rotors. Included are our Severe Duty Brake Pads!!!
NORMAL PRICE for JUST the rotors is $290 but right now you cant get everything AND PADS for $260 SHIPPED within the 48 states INCLUDING HI, AK and PR!!!
WE ONLY HAVE TEN SETS AT THIS PRICE and wants they are sold I take down the special so ORDER NOW as if you come back later this page might be gone!!!
http://6litereaterdesigns.com/store/...roducts_id=237
Which three contiguous states (that would ordinarily get everything for $260) are being replaced by Hawaii, Alaska, and Puerto Rico? I don't wanna be living in the state that gets screwed by surprise, you know?
I just ordered all four cross-drilled/slotted rotors and powerstop pads for 180 free shipping from Brake Motive on ebay. Had this package before on other camaro, really good and obviously can not beat this price.
We use what I like to call the RCC "Radius Camfured Cut" The cross drilling and slotting are machined this way to properly dissipate hot gases so that the machine work will not crack. Most companies don't do this. Because it will take 3 to 4 times longer to machine a pair of rotors.
The pads are the Severe Duty pads that I have on my own Camaro (have these rotors as well). I would consider them a premium pad. Comparable to Axxis/PBR Metal Master brake pads in terms of Performance minus the dust. Comparable to Hawk HPS pads in terms of rotor and pad wear and low noise. They are semi-ceramic...
Thanks for that info. I was wondering what the pads you are including with the kit are like. I have a lot of trouble with brake dust on my current front pads, and was hoping the combination of the rotors and now these pads will hopefully cut down a bit on the dust.
As for other people, if you don't have anything helpful to add, why even say anything? Sure, you can find cheaper setups, and that's what they are, cheaper.
Sorry to further bump an old dusty thread, but oh well. I'll probably get yours when mine get to the point where I shouldn't use them anymore.
Hopefully you'll be having a special then though.
