Heim Joint Boot ?
Heim Joint Boot ?
I did a quick search on here and didn't find my answer, so here goes:
This weekend I installed a whole bunch of suspension upgrades for a 2000 B4C and 2002 Z28. The list includes the heater hose mod for each, Poly/Poly LCAs on the Z, Founders' double adjustable (heim/heim) PHB and corrected Torque Arm pinion angles. I'm reflecting, and though I know people prefer the Polyurethane ends on LCAs for road noise, I'm concerned they won't last if I do any kind of cornering due to binding. I don't intend on road racing, but the car with the Poly/Poly LCAs is a daily driver.
So now I understand why a Heim Joint may be favorable for LCAs and perhaps a PHB, what with the articulation in the rear end. But road grime will ruin these Heim Joints eventually. I've heard and read about Heim Joint boots to protect these ends. It sounds like the best for a daily driver would be Heim Joints with boots, but I don't see any information about boots on Founders' website.
Here are the questions: do Heim Joint boots help in our daily driving applications? Assuming LCA and PHB ends are the same size, what size Heim Boots should I be looking for? Any kind of feedback will be appreciated!
Which one are our LCAs and PHB typically? I have Founders' pieces, but I recall my UMI pieces being similarly sized. Thanks for the response!
Installed 5 boots this weekend, they fit REALLY tight! Founders' expressed concern that water could get in and ruin the joint, but these things fit so tight since a 3/4" is on the bigger side for a RERS-3, I have no clue how any appreciable water could accumulate in these things...
Location: Land of the Mormon's although I'm not one of them
I never used the boots, but I did use the regular seals-it seals and they worked great for about 35k miles, which is when I replaced the Rod-Ends; and while they were bad, they weren't completely shot.
I was wondering, are the heim joints used on UMI and BMR torque arms the same size as the ones used on their PHBs and LCAs?
Edit: Nevermind, they are 3/4" for PHBs, LCAs and TAs
I was talking about on your adjustable torque arms near the rear, and not the holes to bolt the torque arm to the rear end housing... is this what you are referring to? Because your site indicates you use rod ends.
From PN 2205:
"This set-up features on-car adjustability for easy pinion angle adjustments using a 4140 Heat treated adjuster and ¾" QA1 Rod ends, truly the ultimate arm on the market at the most affordable price!"
The description is incorrect, it should say rod eye not a rod end.
http://www.umiperformance.com/catalo...roducts_id=456
