Precision Turbo 76GTS + (Complete KIT) ***SOLD***
Category: Engine - Power Adders
Price: $1
Location (State): OH
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
I have a Precision 76GTS (T4 .96 A/R) Turbo For sale with wrapped LS hotside, 3" aluminum cold side and extras!
Specs from precision>
600-1875
76HPSH Boosted
1,150 HP
TH81HPS TH96HPS
T4 Tang T4 Tang
.81 A/R
.96 A/R
Inducer 3.228" (82mm)
Exducer 2.960" (75mm)
Journal Bearing 4" Inlet / 3" Outlet
Inducer 3.200" (81.3mm)
Exducer 2.960" (75.2mm)
Turbo has little run time since it was sent out for inspection in 2010. This turbo spools very quickly on the street, it's just too small for my 408. Estimated HP for my setup was around 750 HP.
Includes:
Precision 76GTS (T4 .96 A/R) Turbo W/fittings for oil supply and return lines.
Complete Wrapped Hot-side -- Setup for O2 and wide-band sensors.
(Lower crossover pipe needs re-wrapped: Pipe scraped the ground before I had the suspension setup properly)
Turbonetics NewGen Wastegate
Complete aluminum cold side including a 4.5" x 12" x 31" (24" Core) A2A inter-cooler. Vibrant (Quality) silicon coupling included with t-bolt clamps. Throttle body coupling not included. (Pictures to come)
Tial-Q 50mm BOV (RED)
(-4) AN oil supply line & fittings w/engine block manifold (Bolts to oil pan)
(-10) AN oil drain line.
T4 Turbo blanket
4" Air filter
Alternator relocation bracket
SOLD
Notes: Kit will require A/C delete, radiator relocation, and alternator relocation. Works with factory K-member. May require solid motor mounts as shown.
If you end up parting it out i would be interested in a few things. I already have a KYTP hot side and a 76GTS.. i would be interested in the drain/feed lines, filter, blanket etc..
I will let you know when I do!
So are you going to sell the BOV and wastegate?? I know you initially said you would like to hols on to them. But if someone waved $100 bills in your face how many would it take for you to relinquich them?
Also the Alt Relocation Bracket
