rear brake pads, headlight gears, upper ball joints, PHB + brace
Category: Accessories
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, Front wheel drive vehicles
Location (State): KS
Item Condition: Used
LS Engine?: Fits LS Engine
stock panhard bar (good bushings) and support bracket - $25 shipped
Brand new Moog lower ball joints 93-02 fbody K6145T - Sold
Brand new upper ball joints 93-02 fbody K6462 - $15ea or $25 together
Brand new Moog front lower control arm bushings K6490 - Sold
Used plastic headlight gears for 93-02 firebird, good shape not stripped. - $10ea $15 together
Fbody LS1 oil pan/windage tray/dip stick/oil tube Used - Sold
93-02 black strut tower brace - Sold
LS1 fuel rail with injector clips - Sold
Fbody softline fuel hose from hardline - Sold
-4 feed line 14' (enough to run from trunk to engine fbody) - Sold
HSW 78mm plate w/ hardware and throttle cable mount - Sold
Stock fbody throttlebody wit TPS and IAC - Sold
85mm delphi truck MAF never ran - Sold
LS1 fbody pan oil pan baffle - Sold
LS1 fbody oil pan gasket fel pro, new - Sold
2 Moog sway bar end links fbody (fits front or rear) - Sold
2 metal headlight gears for 98-02 firebird (I believe they fit 93-02, and c5 vettes) - Sold
LS3 coolant crossover - Sold
LS1 rocker arms w/ comp's trunion upgrade- Sold
Manley 7.350" .080" wall chromemoly pushrods - Sold
LS1 ignition coils w/ bracket and harness - Sold
LS1 center bolt valve covers - Sold
Stock LS1 PCV and PCV hose w/ 10,000 miles, great shape - Sold
Nitrous 4 port switch panel w/ 3 on/off and one 3 position switch - Sold
Stock LS1 rocker arm pedestals - Sold
NEW 12pt polished stainless LS1/LS6 intake manifold bolts - Sold
Nitrous line, nitrous switch panel, brake pads, OE oil pan baffle, felpro pan gasket, sway bar end links, headlight gears, OE panhard bar, manley pushrods, valve covers, and OE PCV hose are still available.
To the top!
To the top!
