Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
93 Z28 project
Old 05-08-2016, 12:56 PM
sierravmax's Avatar
Default 93 Z28 project
My parents gave me this car over 2 years ago. They originally bought it new in 93. It was equipped with a Lt1/700r4 and had the performance axle with the 150mph speedo. It sat under some trees for about 3 years and had 220,000 miles when I got it. I bought a new battery for it and drove it home and gave it a good cleaning.
Old 05-08-2016, 01:13 PM
sierravmax's Avatar
The car had some running issues and would throw a code for 02 sensors and opti. The car was leaking oil all over the place also. I tried messing around a little with the Lt1 and said screw it. I am doing a Ls swap. So I went ahead and bought a 2005 Lq4 pull out, Ls6 intake, and F-body oil pan to start.
The day I picked up the 6.0 form the UPS freight center.
Got the motor in the garage and started stripping it down.
Test fitting Ls6 intake.
Started cleaning up the block.
Got some new parts in.
99-02 Fbody engine harness.
Old 05-08-2016, 01:17 PM
CamaroWhoopAss's Avatar
The tranny is a 4L60, not 700r4 fyi.
Old 05-08-2016, 01:28 PM
sierravmax's Avatar
UMI road race K-member
SLP mass airflow sensor
Arp balancer bolt
Right before tear down
Look at all that oil. All on the bottom of the car also.
Drilled hole and tapped to mount alternator.
Running 04 ZO6 valley cover and rear ctsv steam vent. Front steam vent is a stock Ls1.
Old 05-08-2016, 01:45 PM
sierravmax's Avatar
Finished cleaning motor and bolted down intake with stainless Arp hardware
My only pcv hose. It really cleans up the engine.
3 wire 98 temp sensor. 2 wires go to the pcm and you have to add a wire to go the gauges.
F-body oil pan cleaned up
Brother donated his stock manifolds since he has Lt's. Installed some new studs.
Brand new bellhousing. These things are getting expensive.
Pilot bearing tapped in and new seal.
Monster 28lb flywheel
Monster stage 2 clutch.
Old 05-08-2016, 01:57 PM
sierravmax's Avatar
Front end accessories situated
Truck coil packs cleaned and bolted down
Test fitting new pedals
Removed steering column. Made pedal swap way easier.
Hole cut. Some say to leave the rubber insulation, but i ended up cutting it out.
What it looks like under the hood
Tick adjustable master cylinder.
Old 05-08-2016, 02:28 PM
sierravmax's Avatar
Prothane engine mount inserts. Comes with new bolts to clamp them back together
T-56 finally came in. Later on I found out that this was a piece of junk
Slave cylinder installed and tick speed bleeder
All bolted together
Putting it in.
All in
Cut hole out.
Test fitting boot
Shifter installed
Port that was used for the Lt1 oil cooler. Found a plug at Napa. Later on this plug cracked and failed. I ended up going with 5/8 radiator hose with a brass plug clamped on the end.
Test fitting K&N intake.
Old 05-08-2016, 02:50 PM
sierravmax's Avatar
Intake elbow all figured out
Corvette fuel filter/regulator in stock filter location.
Shortened heater core lines and installed new hoses
Ran steam vent hoses
New starter as i damaged the truck starter
Didnt run the clutch switch yet so i just jumped out the shifter connector so i could start the car
Removed balljoints and bushings for replacement. I had a full energy suspension front upgrade kit
All finished and driving.
My tires were dry rotted so i stole my brothers Ws6 wheels
Just enjoying the car.
Old 05-08-2016, 03:52 PM
sierravmax's Avatar
So I drove the car around here and then for 6 months and had issues with 3rd and 4th grinding, no A/C, and my power steering overheating.
So I bought a Derale cooler for my powersteering. I was amazed that the cooler mount lined right up with existing bolts on the airdam.
So far this has been on the car for almost a year with good results.
Fuel gauge didnt work so i tried to swap out the sending unit. I swapped it out and it still didnt work.
Cut hole out
Gasket material.
Got some aluminum material from Lowes to reinforce the metal.
Started collecting parts for A/C
LT1 lines would not work with stock manifolds. So i bought new Ls1 lines and a crimper and crimped the Lt1 ends on the Ls1 lines.
This was the high side from the condenser. I ended up ordering a new connector so the ferrule would be captured
This is the suction line. I just recrimped it as it is low pressure. You can see the nub that would normally catch the ferrule
All installed
Where it connects to the bottom of the condenser
New battery tray/overflow tank. Old one had broken tab in front to hold down battery.
Old 05-08-2016, 08:22 PM
sierravmax's Avatar
Still have more pictures of things that I have done to the car. Probably will upload the rest tommorrow.
Old 05-08-2016, 09:09 PM
bluestreak98's Avatar
great work!
Old 05-09-2016, 08:39 AM
Nathan C's Avatar
Man that was quite a project! Looks like it turned out pretty well.
Old 05-09-2016, 11:42 AM
sierravmax's Avatar
Thanks. It is actually a little farther along. Tried uploading more pics last night, but I think I hit the limit or something. I lost the whole post and gave up. I also have a thread in the conversions section, but decided not to post anymore in that as what I am doing now has nothing to do with swapping a Ls. I will use this thread to update on all my progress.
Old 05-09-2016, 08:25 PM
sierravmax's Avatar
Here are the new wheels and tires.
Picked up four 18x9.5 C5 replicas fom Oe wheels
Nitto Nt05 275/35
Room full of whèels and tires
Also picked two 18x10.5 for later down the road
Very wide
Old 05-09-2016, 08:40 PM
sierravmax's Avatar
These bump stops are done. Energy suspension to the rescue.
All mounted up. Also replaced sway bar end links and bushings while i was at it
Bunch of oil still under this car from the Lt1.
Had to grind down the rear hubs for the wheels to fit. I used a dremel with a barrel sanding wheel.
All installed!
Got lucky and found a black berger panel at a local scrap yard
All installed and cleaned up
Old 05-09-2016, 08:54 PM
sierravmax's Avatar
See if you guys can guess what I was doing in these pics. Will post the results tomorrow.
4x4 style
Brothers car on left and mine on right and both in the air.
Hmmmmm
Old 05-10-2016, 01:37 AM
one fast zo6's Avatar
VERY NICE and you do great work.
Old 05-10-2016, 02:34 AM
Ok, now get some pretty brakes on there to match the rest....
Old 05-10-2016, 08:38 PM
Z28 6spd's Avatar
Really nice job on this car!
Old 05-10-2016, 08:56 PM
sierravmax's Avatar
Thanks. Brakes will eventually come. Still trying to spend money on problem areas before full out upgrades.
Well here is the reason I had the car all jacked up. I got my taxes back and my transmission has been grinding 3rd and 4th ever since I put it in. Just recently it wouldn't shift into 5th, 6th, and reverse. So I decided to pull it out to rebuild myself. And I am glad I did considering how much I spent on parts.
T56 removed. I used a ATV/ motorcycle jack to get it out
Input shaft is toast. So I ordered a new one and a pilot bearing.
Broke front plate loose to drain the rest of fluid
Removing roo pin from cup holder
Shift rail and reverse lockout
Built a lttle jig to hold it off the workbench
Tailhousing removed and you can speedo reluctor wheel and reverse gear. Reluctor had somr knicks in it.
Removed gear and you can see synchro assembly and brass blocker
Removing detent plate
Harbor freight puller that i modified with longer arms for 5th/6th cluster
Sychronizer keys with missing magnets
Main case removed
1st/2nd shift fork on top 3rd/4th on bottom. Notice how 3rd/4th is still aluminum
Quick Reply: 93 Z28 project
