INJECTORS OR LS6 manifold?!?
Old 07-26-2016, 05:26 PM
LS1TAUTO's Avatar
Default INJECTORS OR LS6 manifold?!?
Doin a torquer v2 cam with ported 243s, should I either stick with stock ls1 manifold with 42lb injectors or ls6 manifold with Stock injectors can't do both or i will be shot by wife help me out guys thanks
Old 07-26-2016, 05:51 PM
HCI2000SS's Avatar
To be safe I'd upgrade the injectors
Old 07-26-2016, 09:16 PM
LS1TAUTO's Avatar
Cool bro thanks for the response!
Anyone else?!?!?!?
Old 07-26-2016, 09:21 PM
farmington's Avatar
You MIGHT be able to get by with the stock injectors. I vote for the LS6 intake. Keep an eye out for some GTP injectors. they're 36# and you can usually get a set for around $100 used.
Old 07-26-2016, 09:44 PM
Majestic9C1's Avatar
Injectors
Old 07-27-2016, 04:33 PM
Mike Morris's Avatar
I have some 42lbers for cheap if you are in a jam
Old 07-27-2016, 04:36 PM
finewayne's Avatar
go with LS6 intake, worth every penny
Old 07-27-2016, 04:53 PM
Jtm2085's Avatar
I get cheap gtp injectors and the ls6 manifold. Tell the wife about it over dinner at a nice restaurant...
Old 07-27-2016, 04:57 PM
LS6 intake leaves a lot to be desired with ported 243 heads
Old 07-28-2016, 06:24 AM
LS1TAUTO's Avatar
How much?!?!?
LS1TAUTO's Avatar
I like that!
Old 07-28-2016, 10:07 AM
Jtm2085's Avatar
True, better than a ls1 manifold though
Old 07-28-2016, 03:46 PM
Originally Posted by LS1TAUTO
How much?!?!?
70 shipped. Check out for sale ad or text me at 410-812-8915 for pics
Old 07-28-2016, 07:09 PM
slogo's Avatar
Says the guy that just happens to have some injectors for sale.
Old 07-29-2016, 08:09 AM
You are right. LS6 is the best one out for a head cam car. SMH. Think before you post
Old 07-29-2016, 09:23 AM
slogo's Avatar
What does that mean?
Old 07-29-2016, 10:17 AM
MuhThugga's Avatar
You are trying to make a decision between a need and a want. If the engine's airflow demands fuel beyond the capacity of your current injectors, then you have to get new injectors. If you add an LS6 intake and it throws the fueling demands beyond the injector capacity, then you have to get new injectors.
If you can't afford the possibility of needing to buy new injectors after getting the LS6 intake, then you should leave the engine as it is and check the injector duty cycle. You also need to keep in mind that the tune needs to be adjusted with any new injector sizing.
Old 07-29-2016, 11:53 AM
slogo's Avatar
I was not aware that a couple of mild bolt on's
would need new injectors. As mild as his setup
is, seems like the seat of the pants would appreciate LS6 intake more.
Old 07-29-2016, 01:11 PM
R6cowboy's Avatar
Very true. I'd imagine the guy is on a budget and anything better is definitely out of the question.
That said OP, an LS6 intake is certainly worth the cost over an LS1 piece. You get what you pay for here.
It may be possible that your setup would need bigger injectors, but they also may be sufficient for the time being. I'd go with the LS6 intake and take Mike Morris up on his very inexpensive offer. It's very possible the stock injectors may be reaching their max capability with your heads/cam setup.
I don't mean to be rude, but I think it would be wise to ignore slogo's comments here.
Old 07-29-2016, 02:31 PM
MuhThugga's Avatar
He is adding a Torquer V2 and ported 243s. I'm pretty positive those stock LS1 injectors are going to be taxed beyond their limit.
Quick Reply: INJECTORS OR LS6 manifold?!?
