4.8 Turbo Silverado
Old 08-23-2016, 10:04 PM
echoman's Avatar
Default 4.8 Turbo Silverado
Thought I'd post my results over here too for reference, since I see some people swapping in a few truck engines in their rides.
'06 4.8 Silverado with some heavy 20" wheels. Running a 3:90 gear and trutrac, 60e with 3k stall. KB racing turbo kit with the BW s369 turbo. Custom spec'd turbo can from LJMS. Trunnion upgrade, and cam springs. 80# injectors, Walbro 450 fuel pump.
Have the 9# spring in only seeing about 7#'s with the cam. Made 460rwhp and 442rwtq VERY conservatively.
https://youtu.be/2AmIkTA48AA
Old 08-23-2016, 10:40 PM
kingtal0n's Avatar
Isn't that turbo capable of 700 or 800 horsepower? Any particular reason you chose such a huge, oversized turbo for a mere 500 to the wheel? Spools pretty dang slow with all that extra weight. you must be planning to go much bigger?
Old 08-23-2016, 10:57 PM
echoman's Avatar
It's a 69mm turbo, so not very big. Plan on pushing 600 to 650 eventually once I get a trans that can handle it.
Old 08-24-2016, 08:33 PM
RealQuick's Avatar
Congrats! Must feel great when the boost hits.
Old 08-25-2016, 01:03 AM
kingtal0n's Avatar
Isn't this the same engine they used in this test?
http://www.superchevy.com/how-to/eng...-mouse-part-3/
I just feel like, you are leaving over 250ft lbs of torque on the table at 3k rpm because of the enormous turbocharger.
I'm wondering if maybe you have a leak? Or the exhaust system is really really huge which is killing low flow cylinder VE. Why was there no A/F curve on the dyno? And why is smoothing set to 5? These are signs somebody doesnt want other people to see whats really going on.
Old 08-25-2016, 06:52 AM
echoman's Avatar
It's the same type of engine. The turbo is not enormous, it's a 69mm, so it's actually relatively small. Only running a 3" down pipe into 3" tubing into a straight through style muffler. The results are pretty typical for this type of setup at the said boost (7psi), timing at 15*, and the afr is 11.4.
Old 12-23-2016, 06:36 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
An engine dyno will load the engine much better than a chassis dyno. This turbo should light off almost instantly.
Andrew
Old 12-25-2016, 08:46 PM
DavidBoren's Avatar
The turbo is perfect for a 4.8L, and I am sure there is plenty more in this combination. Sounds like an excellent start. Power will only go up as you get a little more aggressive in the tune, if you desire to do so. Good job.
Quick Reply: 4.8 Turbo Silverado
