357 rwhp 6.0 with heads and cam th400 12bolt???
Put it up on the dyno to see what it would make not too happy with the numbers but I do have a th400 and 12bolt with a spool don't know how much that's affecting it .also My tune is a bit rich n/a was 11.7 gotta get it tuned setup at 28 degrees at wot
Second graph was with a 200 shot 8 degrees pulled i think it's dropping fuel pressure bad put in recomended jetting from my nitrous outlet plate and went crazy lean upped it 4 sizes and this is what it showed didn't have any bigger jets so left it alone didn't want to hurt anything
6.0 patriot 5.3 heads 231/239 cam ls6 intake and open tsp y pipe on these runs
It's got a racetronix 255 with Hotwire kit on it thought that was good for 600rwhp guess not
The car weighs 3350 and has been a best of 11.00@121 on motor and 9.98@135 on 200 shot with recomended jets and -8 of timing but never had awideband on it can't believe I didn't break anything with that 15 afr on the juice is a Granade
Any help or recommendations of things to look at?
Car has only ever been street tuned on motor
Yea I think so too I know she has ***** can't grip on the street worth a crap on m/t dragradials the owner of the dyno told me to add timing to it on motor so I put it at 32 degrees with my timing tuner from the 28 I had and picked up 10rwhp it made 367 with 32 degrees but I put it back down to 28 sence my tuner says 32 is not safe it sucks my tuner couldn't make it
But it was the same afr at the track right? Also whar rpm did you shift at in 1-2 and 2-3? Thanks a bunch
