Bad ass 347 forged shortblock.
RODS--OLIVER I beam 6.125 with ARP Rod bolts
1219 dollars. 1000+ HP.
JE CUSTOM DOMED PISTONS WITH SIDE GAS PORTS and Pistons have a 300.00 polydyne coating on skirts and tops...
+6cc domed
730 for the pistons plus 300 dollars in coating.
Total for pistons 1030.
JE Custom rings.
180 dollars
2001 ls1 block-3.905 BORE HONED .005 OVER FOR CLEAN UP...
700 dollars for the block.
200 dollars for a new crankshaft.
1475 for the machine work which included...
Stock crank heat treated.
clevit h series race bearings
cam bearings, rod bearings
And assembly
Shipping was 200 dollars for a total bill just over 5000 dollars.
I would like to get 3500 out of the motor complete.
It is ready to be shipped and you could have it within a few days of purchase.
This is not for everyone and is a extreemly built 347.
It will hold a ton of nitrous and get some added compression with the piston design.
+6cc domed
JE Custom rings.
180 dollars
And assembly
This was put together by the same machine shop BADZ used. I went through him when he was a sponsor on here last year. (I am not positive but I think he used LME)
It was very similar build he had as I had similar goals/plans. He ran 9.6-9.8 with his setup spraying very heavily.
I have switched to a 410 cubic inch motor and have been on/off on selling this. I doubt I will use it anytime soon and its time to move on.
Originally Posted by SPANKY LS1
Wow, thats a killer deal! TTT for ya...
Shawn
Shawn
Thanks Shawn.
This is a damn nice build. Hopefully someone that needs a motor will realize this.
I have had some interest from some FI guys.
This isn't the best motor for a turbo setup or supercharger setup.
This is a great NA/Nitrous setup.
With these pistons the only way you could get this motor under 10:1 compression would be by running a 6.0 head and a .060 or thicker head gasket.
Now I am sure I just worried some people thinking this is a real high compression motor.
High yes, streetable on 93 octane defentially.
Here are a couple compression ratio breakdowns depending on the heads your running.
All numbers will be using a stock size head gasket and non milled heads.
6.0 head ~ 10.15
LS1 head ~ 10.7
LS6 head ~ 11.0
5.3 head ~ 11.35
With milling and gasket thickness these numbers will change but that should give a real good idea to those interested.
6.0 head ~ 10.15
LS1 head ~ 10.7
LS6 head ~ 11.0
5.3 head ~ 11.35
Originally Posted by scalemaster
is this motor better than a 402 ls2
SAL
SAL
A really unfair comparision.
A 402 is a completly different setup.
It has more cubic inches and there is no replacement for displacement.
This is more of a apples to oranges comparision.
If your going all out the 402 will make more power and torque.
This is basicially a 9.9 out of 10 when it comes to 347 cubic inch motor's. A aftermarket crank would make it a 10, however the stock crank has proven itsself over and over again. GM acturally made on piece in the shortblock very nice, and lucky for us it is the most expensive piece.
What are your goals for your setup scalemaster?
What kind of budget are you working with?
These would make it easier to suggest my motor or a different motor.
Originally Posted by Boss man
JZ'sTA how much HP do you think this block can handle? Sounds like a great setup but im a little worried about the stock crank?
Stock crank is about the least of your worries.
GM produced a very nice crank when designing this motor and trust me if I felt there was a reason to replace it with a aftermarket crank I would have.
I was planning on running 9's on a DP 250 shot and still believe it is very possible with this shortblock as a great foundation. There is no reason why your couldn't make 500RWHP with a large cam/Very Good heads, 90/90, all bolton's, very good exhaust, and a nice tune.
I was shooting for around 700RWHP with a nitrous cam, and a automatic plus a 250 shot.
This motor will basicially take damn near anything you can throw at it. If you have anymore question feel free to ask.
Extra cubes is always nice.
Let me know if you have anymore questions.
A advantage will be you could keep your current top end with my motor where as a 402 would more then likely require a better set of heads, and larger cam.
This will defentially handle the juice.
The shortblock has some nice components. Looks like it will be a nice set up. However, LME did not build the shortblock. Just wanted to make that clear.
Thank you,
Bryan Neleen
LME
713-849-4505
Thank you,
Bryan Neleen
LME
713-849-4505
Thanks Brian.
Did BadZ not go through you guys to do his shortblock?
I could have sworn that is the company he used back when he was a sponsor.
Anyways thanks for clearing that up.
TTT
TTT
I got the MTI STG2 R heads and fast 90 combo
Well the intake/TB setup is great for either motor.
I would personially change heads if you go to a bigger motor.
Maybe a AFR225/TEA stage 3 or the same heads you have but in the stage 3 setup with larger valves.
The heads will work great on either setup dont get me wrong I would just go to a stage 3 head on a 402.
Anyways looks like you have a real nice top end package. Again good luck whatever way you decide to go and let me know if you want this shortblock.
Thanks again for the interest.
Jeremy
beautiful...... who is building it?
