Happy with your new 12-bolt or not?
This purpose of this poll is to try to quantify the percentage of people that are unhappy with their 12-bolt because of breakage, leakage, or excessive noise. Either Moser or Strange, whatever. If it's broken in, we want to know about it.
And please post up if you're happy with your setup... sometimes all we ever see are the "problem posts", and we have no idea what proportion of the total customers these problems represent.
Thanks in advance for your input...
Rich
I'd be interested to know if you Strange owners with quiet rears raced your cars hard...
I only ran 8 times with the new rear, but still quiet as ever.
edit: 'Saw that you're on Nittos...
Great thread to throw up by the way! I'll be watching this one. Rear is coming next year for me...
A lot of it has to do with how much time the assembly line spends setting up the gears, which apparently ain't too much. If they're too tight, not in line, etc. they're gonna howl, and that's gonna kill your gears, and the heat from excess wear on the gears'll shorten the life of your whole axle. You owe it to yourself to pop the cover off and check the gears for proper backlash, pinion depth, ring gear spacing, wear pattern, bearing preload, and adjust them as needed. After all, you spent over $2000, so make sure it's set up right before just throwing it in, and it'll last you a LOOOONG time.
...You owe it to yourself to pop the cover off and check the gears for proper backlash, pinion depth, ring gear spacing, wear pattern, bearing preload, and adjust them as needed. After all, you spent over $2000, so make sure it's set up right before just throwing it in, and it'll last you a LOOOONG time.
