Rear main seal leak - cost to repair?
I apparently have a rear main seal and oil pan leak on my '01 SS. What might I be looking at to have these repaired?
I "apparently" had a rear main leak on my '02 but it turned out that the oil pan bolts were loose...at 14,000 miles. So hopefully thats your problem because when it was originally looked at I was told it was the rear main. But what your looking at to have them repair I am not sure of.
Yeah, I definitely just had that done on my 99' WS6 along with the pinion seal and the machanics fixed all of the seals for under $400 so I hope this helps you...Oh yea and it's definitly critical because when mine leaked for a while I seriously felt a difference when I shifted.
Well, I was quoted $450 at a performance shop which I thought was high until I called a dealership...$1100!!! They also wanted $125 for the pinion seal, and if I recall, $500 for the oil pan.
I need to find someone to do them all for $400, but I'm not feeling hopeful.
i had to have the dealership replace my transmission and headers because of hitting a road hazard and now i also have an oil leak. i'm wondering if mine is a rear main seal also. i'm going to check to see if the oil pan is bolted tight later today as well
the rear main seal costs a lot because in order to get to it you have to pull the tranny, and flywheel. so it all depends on how honest the mechanic is.. i know for a fact with a lift it only takes about an hour to drop a tranny, i just did it, and after the tranny is out about 2 minutes to pull the flywheel.. and the rear main seal is right there.. so total its only about 2-3 hours of work. plues like 20 for the seal. around here mechanics charge on average 50/hour.. so i wouldnt pay more than 250 for the job.
RMS for the f-bodies pays 3.7 hours for MT and 2.3 for AT. At $90/hr labor rate, it should be $333.00 labor plus parts/tax. AT cars should be $207.00 plus parts/tax. I'm not sure what a RMS runs but it should be more than $30-50. $400-$450 is what you should be looking to pay.
I hope nobody has to go through what I did to get this repaired. I took it to a reputable shop. They doubted highly the oil pan was leaking, so they went after the rear main for $350.
Then it continued to leak after they test drove it, so they did the oil pan for $450. Still leaking at this point...
They pulled the tranny again, put dye in the oil, and used a blacklight to discover where the leak was. It turns out there had been a gouge in the crank and the oil was leaking out thru the gouge.
After about a week and ~$1000, it hasn't leaked again but I'm keeping my fingers crossed.
LS1Tech Administrator
Received 1,492 Likes
I know this thread is 10 years old, but since it's back....
Not sure why so many people commented above about this repair being "critical". I don't agree, unless of course it's leaking badly. My '02 had a minor rear main weep for several years, it never got any worse and wasn't even bad enough to have any effect on the amount of oil used between changes (vs. before the leak.) I just ignored it with no ill side-effects at all.
Village Troll
Yep, as I said, "unless of course it's leaking badly." Mine was an auto so I had no clutch concerns, perhaps those posters above were all M6 people....
If you find someone who will not rip you off.....they should charge about $150 total. You bring the new seal.
My friend drops my transmission in 20 minutes. Seal goes on in 15 minutes. 20 minutes to put the transmission back up.
Try to find someone in a local car group that does side work. I paid my friend $100.00 for the total job. A little over an hour we were done.
9/10 is pretty high. High horsepower will definitely make it more likely to crack one. Most the cracked flex plates I've seen were on Diesels. I've seen a few cases where the problem was a missing dowel pin. It ripped the center out of the flex plate. In my experience if the flex plate is cracked, you'll know.
As far as the rear main being critical, I disagree, unless it is pouring oil out on the ground. Slow leak and no time or money to fix it? Just leave it be and check the oil level from time to time.
