LS6 Intake, ported TB, NOS 5177, misc WTS/WTT
for sale!!
LS6 Intake with Ported Throttle Body. Throttle Body haas been heavily ported, Epoxied the EGR hole, And fromt halved the blade bar. SOLD!! plus shipping
NOS 5177 Dry Nitrous set up complete with SLP airlid pre-drilled for the kit. SOLD plus shipping
2000 stock injectors $50 plus shipping
also have stock fuel rails, stock 2000 Camshaft, Unported 2000 throttle body, LS1 Intake, stock crank pulley.
WIllingto trade for this stuff and can work out + cash deals as well... or if you just want to sell me something in my list, let me know that too.
PARTS I NEED
TUnnel mounted turque arm
90mm TB
coild pack relocation kit
sheet metal valve covers
42lb injectors (i currently have 36lb injectors but think i need 42's)
tubular upper A Arms
Tubular Lower A Arms
Shaft mounted rocker arms
wide band
here are SOME pics, can take more of other stuff if requested
NOS 5177 Dry Nitrous set up complete with SLP airlid pre-drilled for the kit. $300
PARTS I NEED
90mm TB
wide band
[snapback]22051[/snapback]
kit comes with the everything it came with new.
15lb bottle
solinoids
WOT switch
WOT swith bracket
Bottle brackets
Blow down tube
Electronics
FPSW
the bottle is a little over a year old, but was only sprayed a few times.. literaly..3 times. my car has been down for many months now, so it has had no use.
if i where to sugjest replacing something on it, it would be the WOT switch and the WOT switch bracket because they are bent for my set up.. might work on yours too, but couldnt gaurantee it.. but you could get those for less than 20 bucks. It didnt come with a window switch or purge, so if you wanted to run those you would have to buy your own. other than that, just some basic wiring suplies and you would be set.
15lb bottle
solinoids
WOT switch
WOT swith bracket
Bottle brackets
Blow down tube
Electronics
FPSW
Originally Posted by cablebandit
look into getting the PTM 90mm tb. Much cheaper than Fast/NW and very nice!!! I have one on my car and should be in the 850rwhp range....drives like stock
I second the PTM. I have one and I like it as well.
Originally Posted by 04ctsvfl
how much for just the TB, I have an ls6 with volant intake, magnaflow exhaust, and a tuner, what sort of power will I see, with the addition of this TB????
Just went to take pictures of everything and realized that i forgot about something with the intake. When i bought it from FFHP, a small peice on the front corner had been broken off, but they eppoxied it back on so it looked ok. where it broke was not an importeant part, has nothing to do with the functinality of the intake. it is just a peice of plastic.
