lots of parts form a 98 camaro z28, 97 trans am, 96 camaro z28, and a 95 formula
i have parted out several cars and still have lots of parts left over
98 camaro z28 M6 with 42k miles
radio bezel-$40
HVAC controls-$25
headlight controls-$20
stock injectors (8)-$40
door handel bezels-$10 set
Drivers door in red complete with window-$100
z28 hatch in red with spoiler-$50
tan leather seats (not in very good condition)-$100 for the set front and back
tail lights (drivers one has a 2 in crack in the yellow lense but it's not very noticable)-$75 for the set
e-brake handel assembly-$25
rear tan seat belts-$30
hatch struts-$20
tail light wireing harness-$20
washer fluid resivor with motor-$10
dash in ebony-$150
passenger air bag-$40
steering column with airbag and steering wheel-$150 or $50 for the airbag and $100 for the wheel and column
front shock/strut assemblies- $60 pair
pair of LS1 z28 crome rims with centercaps and good tires-$60
pair of stock axles-$50
hatch weather strip (does not leak)-$10
shock sensor-$7
air bag sensor-$30
red lenses in rear bumper-$10 pair
stock LCA's-$15 pair
rear bumper support-$20
stock torque arm-$20
stock amp-$40
fuel rail assembly-$50
stock exhaust from the manfolds to the i-pipe includes manfolds, cats, O2 sensors, y-pipe, and i-pipe to the rear end-$40 picked up
15 stock lifters and 15 stock pushrods-make offer
tan hardtop headliner (looks new)-$40
steering coupler-$10
brake master cylinder with resivor-$20
brake booster-$15
heater lines-$20
95 formula M6
triangle interior mirror pieces-$10 pair
t-top holders in the trunk-$30 set
brake booster-$10
heater lines-$20
gray cloth seats-$120 for the set front and back
gray cloth door panels-$60 pair
headlight control panel-$20
HVAC control panel-$25
stock 10 bolt with 342's complete-$250
charcoal dash-$150
passenger airbag-$40
drivers t-top-$160
a-pillars-$50 pair
b-pillars-$10 pair
t-top weather strip-$40
formula hatch in silver-$50
mirrors in silver-$30 each
rear bumper in silver-$40
gray front seatbelts-$40
hood strut assemblies-$20
front shock/strut assemblies-$60 pair
gray interior dome light-$10
hatch weatherstrip (does not leak)-$10
idler pulley-$20
stock amp-$25
M6 rubber shift boot-$20
rear view mirror-$20
drivers door (needs new window motor)-$75
tail light center piece-$30
complete exhaust includes hooker shorties, a hooker y-pipe, a high flow cat, a flowmaster muffler, a cutout, and dual tips. i pulled it with out cutting it so you could install in without a welder-$400 picked up
96 camaro z28 M6
defrost switch-$10
white z28 spoiler with 3rd brake light-$25
gauge bezel in ebony-$20
drivers door in white-$100
horn assembly with wireing harness-$20
front rotors in lightly used condition-$20 pair
motor mounts complete set-$40
hood hinges-$20 pair
PCM holder-$10
front brake calipers-$30 pair
stock fuel pump-$20
brake master cylinder and resivor-$20
brake booster-$10
power steering fluid resivor-$20
k-member-$50
stock lower a-arms-$20 pair
97 trans am a4
fog light switch-$15
non ram air stock hood in an after market metalic silver color-$40 picked up
trans am rear bumper in an after market metalic silver color-$80
hood struts-$20 set
stock amp with mounting bracket-$40
a-4 steel drive shaft-$40
complete 323 10 bolt rear-$250
passenger a-pillar-$10
other parts
hatch releast buttons-$5 each
cig lighters in gray and ebony-$5 each
10# edlebrock N2O bottle with pressure gauge-$100
ball milled LT1 front rotors in lightly used condition (less then 500 miles)-$40 pair
Lt1 under drive pulley with belt-$30
set of k-member bolts (6 bolts)-$10
ENKEI 17 in 3 piece 5-star wheels. the rears are wrapped in Nitto 555 extreme ZR's 285/40 ZR17 and the fronts are wrapped in BFG's G-force T/A KDW's 275/40 zr17. i'll take $900 for the set they are very sharpe looking rims. get me an e-mail of you would like pics
18 in gun metal 6-spoke rims in need of tires-$200 for all 4
f-body drivers window-$40
4-bolt main 350 out of a 77 GMC jimmy. it was running when pulled but it has been sitting for just over 2 years. $250 picked up
all prices are OBO and plus shipping
if you need anything else i probly have it so send me a pm.
my paypal is misdswimmer@hotmail.com
i'm located in mansfield tx 76063
thanks
robbie
radio bezel-$40
HVAC controls-$25
hatch struts-$20
dash in ebony-$150
shock sensor-$7
air bag sensor-$30
stock amp-$40
brake booster-$15
heater lines-$20
95 formula M6
brake booster-$10
heater lines-$20
charcoal dash-$150
drivers t-top-$160
a-pillars-$50 pair
b-pillars-$10 pair
idler pulley-$20
stock amp-$25
96 camaro z28 M6
defrost switch-$10
PCM holder-$10
stock fuel pump-$20
brake booster-$10
k-member-$50
97 trans am a4
hood struts-$20 set
other parts
thanks
robbie
Very interested in the steering rack off the 98Z. Please send pics to supajut@msn.com thanks, Justin.
