LT1 Heads And Intake Needed
Old Sep 26, 2006 | 11:47 PM
GIZMO's Avatar
Default LT1 Heads And Intake Needed
Please help me out.
Intake casting number 12552138.
Heads casting number 12551561.
No Porting, no polishing, stock unmodified parts only.
Thanks,
Daren
Old Oct 2, 2006 | 12:03 AM
GIZMO's Avatar
Still looking!!
These would be from a 1997 Firebird or Camaro with an LT1.
Old Oct 2, 2006 | 12:21 AM
streetwarrior96's Avatar
I got a mostly complete motor from a 1996 formula 83,300 miles. No opti, no alt, no starter, no water pump
Old Oct 2, 2006 | 07:49 AM
GIZMO's Avatar
What casting number heads and intake does it have? Where are you located?
Thanks,
Daren
Old Oct 2, 2006 | 09:53 AM
Let me see if I can get some pics. I am located in South Texas
Old Oct 2, 2006 | 12:31 PM
porksoda's Avatar
I've got a set of those heads. Stock, untouched with valves and springs
Old Oct 2, 2006 | 01:17 PM
GIZMO's Avatar
Please instant message me a price including freight to 28150.
Thanks,
Daren
Old Oct 2, 2006 | 09:27 PM
Shon Herron's Avatar
Did you get this stuff?
Do you have other castings and just need these specifically? If that is the case I can have my castings looked at, they are near you in Concord. ie meaning if you have other casting and need these specifically we might would just swap....
Old Oct 2, 2006 | 09:44 PM
GIZMO's Avatar
Shon,
Look and see what you have and let me know. I have some old stuff sitting around, so I am sure that we can do something. The NHRA changed the specs. for the 1998 LT1, so I am short on castings.
Thanks,
Daren
Old Oct 2, 2006 | 10:38 PM
porksoda's Avatar
You can have the heads I'm selling for $250 shipped
Old Oct 2, 2006 | 11:08 PM
GIZMO's Avatar
PM sent.
Old Oct 3, 2006 | 06:27 AM
I bet they did do some changing to the 1998 LT1
As a matter of fact, where can I get a '98 LT1?
Originally Posted by GIZMO
Shon,
Thanks,
Daren
Old Oct 3, 2006 | 06:35 AM
GIZMO's Avatar
Shon,
In 1998 there were a lot of fast LT1 Stockers. When the LS1 first came out nobody new how to make one run. The LT1's were actually faster. To fix this GM told the NHRA that they built a bunch of 1998 LT1 cars and they gave Ram Air front ends to a bunch of teams to get the new body style in front of the public. I have never seen or heard of a factory built 1998 LT1 car. I do know of a couple of "Body In White" factory cars that were built.
Daren
Old Oct 3, 2006 | 06:39 AM
GIZMO's Avatar
If you run a LS1 and call your car a 1998 the NHRA/IHRA will DQ you!!
Old Oct 3, 2006 | 06:50 AM
Interesting!!
I will make the call and see what is up there....
PM Me your number.
Shon,
Daren
Old Oct 4, 2006 | 11:15 AM
NotACop97Z's Avatar
Still looking for heads? I dont know the casting numbers but I just pulled mine off.
Old Oct 4, 2006 | 12:50 PM
GIZMO's Avatar
PM sent.
Old Oct 4, 2006 | 09:34 PM
96capricemgr's Avatar
A friend stopped to get a spare intake of a different casting number from me and that got us to wondering so we looked at the intake on my heads/cam motor it is a 138, that intake came off the original 1996 L99 the car came with, it is ported and milled to match the heads so this one is of no help. I only mention it incase it helps you track down another should you need too. L99 parts are dirt cheap compared to f-body stuff too because most do not realize just how much interchanges.
Old Oct 4, 2006 | 09:47 PM
GIZMO's Avatar
Thanks for the heads-up. I wonder when GM switched to the 138 casting? I originally thought it was a 1997 piece, but am starting to realize that 1996's had them too. Maybe we should use this forum to find out what years had what castings?
Thanks,
Daren
Old Oct 4, 2006 | 10:03 PM
I have access to a handful of 95s and all are the 630s b-bodies and an f-body.
