Slow passenger window? Check this out.
Old Nov 15, 2006 | 07:44 PM
gnomee's Avatar
Thumbs up Slow passenger window? Check this out.
Hello Everyone,
I just started advertising here on ls1tech and wanted to get out here and let everyone see our product.
We are a new company trying to bring new technology to older cars. GM fixed the problem with underpowered windows in there big SUV's but they didn't care much about our f-body's.
We created a cheap kit with VERY detailed instructions that will allow ANYONE with a toolbox to install this kit and improve window motor life and function.
On our site you will see before and after videos. These videos are shot with the cars off and we did not grease or clean the tracks, so greasing the tracks will only improve the benefit of the kit.
The kit is $29.99
Old Nov 15, 2006 | 07:49 PM
camarojunky74's Avatar
wow this looks like a pretty good item i know i have this problem in my camaro
Old Nov 15, 2006 | 08:09 PM
jermzz's Avatar
I have this problem with both my windows. Is this only for the passenger? or would I need 2? Little help here. What's it do exactly?
Old Nov 15, 2006 | 08:23 PM
gnomee's Avatar
This is only a remedy for the passenger window.
By default power comes from your battery, thru your Body control Module on the passenger side then over to the driver side switch. Then back to the passenger window to operate it. This long path of power reduces the amperage and voltage the motor gets by quite a bit.
So your motor is underpowered which
1. reduces motor life
2. reduces motor strength
3. makes the breaker blow and the window stop.
This kit will get power to the window directly from the battery. It will improve power to the driver side when both windows are being rolled up and down at the same time due to the switch on the driver side no longer needing to power the passenger side.
From the factory The driver side is powered fine when it is the only one operating but everytime you roll them up or down together they are both getting hit with low volatage. The kit will wake up your passenger motor, but you driver side may be going out if it is acting like the passenger window.
All the cars in the videos on the site have no driver side issues. Getting this kit before you have problems will only help make sure you don't have these issues early.
Window motors WILL fail like any electric motor, but they should not fail so soon. Our window motors should be able to last over 10 years during normal use when they are properly powered.
HOpe this answers your question.
Old Nov 15, 2006 | 09:25 PM
ProjectCamaro's Avatar
Are you a paying advertiser or just using the site to advertise without paying the fee?
Old Nov 15, 2006 | 10:21 PM
gnomee's Avatar
No we are a paying advertising. Our banner should be up within a day or so. I messed up and did not give them our url so they could not get the banner up today.
Old Nov 16, 2006 | 10:26 AM
cmblack13's Avatar
just bought some! I purchased 2 of them....just to make sure because i had my drivers motor go out and replaced and i still have issues with the drivers side getting stuck...never had problem with the passenger side loosing power...kind of wierd but i think the motor be out that i replaced the drivers with...
Old Nov 16, 2006 | 11:16 AM
TransSlam's Avatar
just ordered one! hope it works
Old Nov 16, 2006 | 11:35 AM
Z284U2TRY's Avatar
Any pictures of the install?
Old Nov 16, 2006 | 12:07 PM
gnomee's Avatar
Empty your PM box. Tried to send you a link and it said your box is full.
Old Nov 16, 2006 | 02:54 PM
Matt D's Avatar
Retired Street Racer
Are these guaranteed to fix the problem or my money back?
Old Nov 16, 2006 | 03:00 PM
2002CobraKiller's Avatar
Both of my windows work and get stuck in the middle of rolling up or down. I know the motors are just burning out but will this kit solve the problem, or will i still have to purchase new motors for both sides?
Old Nov 16, 2006 | 03:11 PM
bluehawk2's Avatar
Is this just for the passenger side window, or is this for the drivers also??
Old Nov 16, 2006 | 07:26 PM
gnomee's Avatar
This kit should solve the problems shown in the videos on our site. If your issue is not a poor performing motor and more of a motor already failed then the kit may not wake your motor up.
It will however help the new motor last alot longer.
If you purchase one of our kits and it does not affect your motor problem at all, you may ship the kit back to us for a refund of the $29.99.
Old Nov 16, 2006 | 07:28 PM
gnomee's Avatar
This kit will only help out the passenger side at all times. It will help the drivers side in situations were you are rolling both windows up and down since they will no longer be sharing power once the kit is installed.
If your drivers side window stops early it is throwing the internal breaker in the motor and is most likely failed. The passenger side is so under powered from the factory that even after it gets to this point it is so early in the motors life cycle, that giving the motor proper power will make the motor work again.
The kit is only for the passenger side.
Old Nov 16, 2006 | 07:38 PM
Raleigh TA's Avatar
The guy's description says that the kit fits only the passenger side, but you will see a benefit on the driver's side at times when you raise both windows simultaneously. When the driver presses the two buttons together, juice is pulled from the same source and neither motor is properly powered. He claims the kit fixes the dual motor pull is eliminated since the passenger side will be pulling juice straight from the battery.
Hope this helps.
I am ordering one soon, winter seems to be harder on the window than summer, and summer wasn't pretty.
Old Nov 17, 2006 | 01:46 AM
MyWs62FaST4u's Avatar
keep the results coming, im interested as well...
Old Nov 17, 2006 | 03:24 AM
BayAreaSS's Avatar
Im also interested
Old Nov 17, 2006 | 09:34 AM
taintedmeat's Avatar
Cool looking product.
Old Nov 17, 2006 | 06:50 PM
gnomee's Avatar
Thanks, we shipped all orders out today. Hopefully next week we will get some feedback for everyone.
