Itimized part out list..
Old Feb 27, 2007 | 06:17 AM
Country Boy's Avatar
Senior Member
Default Itimized part out list..
Itimized list of stuff for sale. All parts have less than 300 miles unless noted and prices are shipped and insured:
FMIC/ kit. OBX from Ebay. 32x12x4 Perfect with 3” in/out. I have the pipes to sell as a whole kit WITH Tial 50mm BOV. Pipes are 3” polished stainless. $150 for just the FMIC or $475 for allpending
Turbonetics Racegate with new flanges $175
ASP pulley with both belts. I will need your stocker and belts. 10k miles $150
ASR/ TCS reversal module $50
T56 rebuilds stage 4 6 speed. Parts are: New 1-2 Slider, New 3-4 Slider, New 5/6 Slider, New Reverse Slider, New Mainshaft, New 1-6 Gears (Depending on Core Condition), Carbon Fiber Synchros, 3-4 Billet Keys, New Mikronite Finishing on 1-4 Gear (Mikronite extends the life of the transmission by more than double), Mikronite Finishing on 1-2 Slider and 3-4 Slider, Steel 3-4 Fork, Bronze Fork Pads 1-4 forks, New Bearing and Labor.....$2250.00 (21 day lead time for Mikronite finishing) $1500 but I need your working 6 speed
Textrilia clutch setup. Pressure plate, disk, flywheel, ARP bolts. Not slipped or raced. [/b]$650[/b]
MAF transilator. Has about 5k on it. $75
Camaro SS sub box. Comes with the Kicker Grills. $150
Amp rack. Black carpet and fits perfect. $100
BMR chomoly STB. Silver $100
Check back often. Im sure theres more Ill find when I go to the garage. This was all from memory.
Old Feb 27, 2007 | 06:42 AM
AtlasEngr's Avatar
Default Harlan shift light
I'll give you $35 shipped to 78562.
LMK>
Old Feb 27, 2007 | 06:53 AM
Senior Member
I believe its sold already..
Old Feb 27, 2007 | 08:01 AM
ls1camar0girl's Avatar
I'm looking for the t56 1-2 & 3-4 synchros? Are you willing to part with just those? if so, how much?
Old Feb 27, 2007 | 07:27 PM
Senior Member
The tranny is staying as a whole. I dont want to be left with a carcus.
Old Feb 27, 2007 | 09:43 PM
sho-me speed's Avatar
Closed ex-Sponsor Account
PM Sent. Are you selling the gauge pod also. Interested in the fuel gauge, shift light, ASP pulley and radiator cover. How much for all shipped to 65803?
It is the underdrive pulley?
Old Feb 28, 2007 | 04:38 AM
cablebandit's Avatar
if the does the i/c "kit" come with the silicone/clamps pictured? do you take paypal?
Old Feb 28, 2007 | 07:09 AM
Senior Member
Yes, the kit comes with everything pictured. Clamps, couplers, FMIC, BOV, pipes...
I have it on hold for someone right now, but I will know something Friday.
greatwhite. The light is sold, but Ill get you a price on the other stuff.
Old Feb 28, 2007 | 08:58 AM
Josh@KY-Turbo's Avatar
I want:
All 25 3" T-bolt clamps. 25x$3= $75
All 24 Silicone couplers 24x$5= $120
The 5 Polished 3" SS bends $75
$270 total Shipped. PM me a paypal addy and I will get the $$$ sent out.
Old Feb 28, 2007 | 09:28 AM
Senior Member
updated!
Old Feb 28, 2007 | 11:04 AM
Senior Member
lunch bump.
Old Feb 28, 2007 | 05:01 PM
Senior Member
topss
Old Mar 1, 2007 | 08:16 AM
Senior Member
toppp
Old Mar 1, 2007 | 01:36 PM
red91z's Avatar
LS1TECH Sponsor
sent you a pm
Old Mar 1, 2007 | 11:27 PM
Frost's Avatar
Man that cold side would look NICE on my car....
Old Mar 1, 2007 | 11:33 PM
Phantompooper's Avatar
Can you PM me the price for the fan shipped to 92128? I will paypal you tonight for it.
Old Mar 2, 2007 | 03:32 PM
badmfkr's Avatar
Default 1?
1? why would you go to all the time effort & $ then demasculate it?
I won't believe it's to warm for turbos down there.
Old Mar 2, 2007 | 04:30 PM
Senior Member
no. Since the housing bubble busted, I am practically jobless since I do new construction. I already have my truck (04 GMC) I have to keep for work and the SS was never a DD. I cant afford both anymore and now Im demodding the SS and selling it. I worked 3 days last month.
Old Mar 2, 2007 | 05:31 PM
badmfkr's Avatar
Default job
sorry to hear why you're selling the SS, I understand the demasculation.
I didn't intead on being nosie.
Old Mar 4, 2007 | 03:15 PM
Senior Member
bump..
Id like to sell everything..
Ill sell ALL this for $4300 SHIPPED!!!! The *** is the stuff thats sold as of right now! Pretty mucha complete minus the cold side.
PTS tubular headers
all piping is above K member
2 1/2” crossover
3” downpipe (goes above K member)
All hot pipes coated in 2000* black coating
hot pipes also wrapped in heat wrap
Wideband O2 bung in DP
***3” polished stainless coldside/ intercooler piping
***4” thick x32x12 polished front mount intercooler
***4 ply silicone couplings (black High Temp Silicone ***and Hose Techniques brand)
***All T-bolt clamps
All V band clamps
***Purple Tial 50mm BOV
Polished Tial 38mm wastegate w/ 6lb spring
Turbonetics manual boost controller
Aluminum restrictor (.060) for turbo oil inlet
-4 oil supply (with fitting for pan)
-10 oil drain (with fitting for pan)
All vacuum lines
Turbonetics T76MPS (the MPT was renamed) (supports the same power at T76GTS, but spools faster than the GTQ) with polished compressor cover and coated turbine cover
***Turbo blanket
Autometer 2 1/16” Cobalt vac/ boost guage
External Power steering cooler with hoses and adaptors
New PCV system with hoses
Dry element air filter
Polished BMR radiator plate
***Dual Flex a Lite pusher fans (fits in front of a/c condenser/ radiator with NO cutting)
1 12” puller fan with relay and switch
Alternator relocation bracket with bolts
2 Gatorback belts (fits with ASP crank pulley)
8 sparkplug wire guards with 4 additional heat sleeves for drivers side
GM 2 bar MAP sensor
My HPT 2 bar SD tune file. Tuned for 12 PSI
Both drill bits and taps to drill and tap for oil lines
upper radiator hose
