89Notch 5.3/T76 turbo/th400 etc Build Thread.
Here is a basic rundown:
89 notch some weight removal
8 point cage
weld in sub frame connectors
Tubular control arms ,poly bushings
4 cyl front springs with 90/10 drag struts
v8 rear springs with 50/50 drag shocks
built 8.8
moser 31 spline axles w/ c-clip elims
strange 31 spline spool
girdle cover
15x3.5 draglites with 165r front tires
15x10 drag lites with 275/60/15 M/t drag radials
BIG fmic
custom built turbo kit with ceramic ball bearing T76
04 5.3
ls1 car intake
ported tb
arp rod bolts
comp 212/218 and .522/.529 lift on 114 LSA
comp 918 valve springs
comp 7.4 hardened pushrods
Built th400 reverse pattern full manual valve body
tci 3800 converter
16 gallon aluminum cell
aeromotive a1000 fuel pump/ boost ref reg
60 lb injectors
tuned with hp tuners
And now for the pics!!!
A1000
Boost referenced fuel pressure reg
Some T76 action
Looks BIG on the bench
Most recent shots of the motor all buttoned up
single layer pin on 4" fiberglass hood
15x10 with 6.5 BS need a cleaning bad
More pics coming soon as the car is coming back from getting its cage etc
Next is the 16gallon aluminum fuel cell with foam and sender in the spare tire well,Also you can see how the spare tire well is off center in the fox bodies (stupid ford) also the relocated battery with master disconnect and LS1 Plate LOL
Here is my gauge cluster its not 100% done but almost still needs the turn signal indicators as well as the high beam indicator ,the gauges are Auto meter Ultralites all of them are electric except the speedo:
This picture shows the fitment of the roll bar past the stock door panel.....
Here is a picture of the half finished interior ,In this picture you can see the shifter mounted in the stock ash tray hole as well as the tach mounted on the cover for the stock 5 speed opening,and the passenger seat in,you can also get a better view of the roll bar and how it fits in this picture:
