89Notch 5.3/T76 turbo/th400 etc Build Thread.
#204
I actually have another 5.3 that is going to get fully built and make its way into the car, here is the plan:
Diamond forged pistons
Compstar H beam rods
Bored to factory 346 bore size
Stock crank
Arp Main studs
Arp Head studs
Gm MLS or Cometic Head gaskets
Ported GM 317 6L heads
probably around 15-18 psi again
With the possibility of adding some bottle to the mix
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#205
Combo is as follows.....
2004 gm 5.3 lsx based truck motor(Cylinder heads have never even been off the motor)
comp 212/218 and .522/.529 lift on 114 LSA
Arp cam retainer bolts
Arp rod bolts
ls6 Corvette intake
Ported Throttle body
60lb injectors
comp 918 beehive valve springs
comp titanium valve spring retainers
comp 7.4" hardened pushrods
stock Ecm tuned by Horsepower Soloutions VIA EFI Live
Custom turbo kit built by me
Turbonetics Tc76mps Water cooled ball bearing turbo
Turbosmart 38mm wastegate
cheap blow off valve
3" Open downpipe
Never got a chance to turn the boost up anymore as food poisoning took me out of commission lol
Cars best Et was 9.99@140.6 with a race weight of 3190 lbs and lots of 10.0 - 10.1 passes this year total I made right around 130-150 passes with ZERO breakage,aside from a couple of rubber intake boots.
![](http://i116.photobucket.com/albums/o4/puggs25/th_DynoDay2008008.jpg)
![](http://i10.photobucket.com/albums/a142/tirefryin_s10/Mailmanbeston165psiHOT.jpg)
Arp rod bolts
ls6 Corvette intake
60lb injectors
3" Open downpipe
![](http://i10.photobucket.com/albums/a142/tirefryin_s10/Mailmanbest.jpg)
#207
the rear suspension set up ... Over the winter the car will get proper rear suspension parts along with some other things and should run consistent 9.70s with a dip to the 9.50s if all goes to plan.
#212
single digit dreamer
we did add a hp motorsports antisway bar in the back. that helped a lot.
we also used a instant center of gravity calc tool to help us adjust the rear suspension. it doesn't seem to be working right now but here is the link >> http://inductionmotorsports.com/im/ic.html
#213
Just an update for you guys, Keep in mind in these pics nothing was really finished, the fuel lines etc need to be re-done. the hot side needs to be cleaned up etc.
New built diff :
8.8 with welded tubes
Moser 33 spline spool
Moser 33 spline axles with 5 lug 5/8 studs
3.31 Gears
Solid pinion spacer
T/A Girdle cover
North race cars cobra rear disks
Full new rear suspension:
Team Z relocated Upper control arms
Team Z adjustable Lower Control arms
Strange Adjustable shocks
Competition engineering Anti-roll bar
![](http://i10.photobucket.com/albums/a142/tirefryin_s10/DSC01183.jpg)
![](http://i10.photobucket.com/albums/a142/tirefryin_s10/DSC01181.jpg)
Started on the new turbo build:
Twin MP T70 Turbos
Twin Turbosmart 38mm Gates
Single Tial 50mm style Blow off
2x 2.5" Cold side - into 3" before intercooler
2.5" Hot side pies
3" Downpipes
![](http://i10.photobucket.com/albums/a142/tirefryin_s10/IMG_1176.jpg)
![](http://i10.photobucket.com/albums/a142/tirefryin_s10/IMG_1173.jpg)
![](http://i10.photobucket.com/albums/a142/tirefryin_s10/IMG_1174.jpg)
![](http://i10.photobucket.com/albums/a142/tirefryin_s10/IMG_1175.jpg)
![](http://i10.photobucket.com/albums/a142/tirefryin_s10/IMG_1177.jpg)
![](http://i10.photobucket.com/albums/a142/tirefryin_s10/IMG_1178.jpg)
Also doing a fully built motor:
04 6.0 Iron block
Stock crank
6.2" Eagle H beam rods
Custom Diamond Forged Dish Pistons
Custom Turbo Cam
Hand ported 317 Heads
TEA Valve Springs
LS6 Intake
Shooting for 800ish rwhp
New built diff :
3.31 Gears
Solid pinion spacer
T/A Girdle cover
Twin MP T70 Turbos
2.5" Hot side pies
3" Downpipes
04 6.0 Iron block
Stock crank
Custom Turbo Cam
TEA Valve Springs
LS6 Intake
#218
1 Post
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
