89Notch 5.3/T76 turbo/th400 etc Build Thread.
nice seat! how much?
also, believe it or not, that armrest weights 7 lbs!!!! 50resto.com has a little plastic delete plate for it for like $20, not too bad at all compared to what we pay for hoods, rims, etc to save weight.
also, love the paint choice for the roll bar. is it one of those hammered metal look paints in a rattle can?
keep up the good work!
Ill have to check out the arm rest delete ,as for the roll bar paint yes it is hammered metal out of a spray bomb same as my intake and water pump are done with
[QUOTE=PRAY HRD]
also, believe it or not, that armrest weights 7 lbs!!!! 50resto.com has a little plastic delete plate for it for like $20, QUOTE]
you talken abot that thing on the consill
Well heres a few more update pics ... the car is sitting on all fours there is still a bunch of weight to go up front so it will sit lower still and then a couple hundred pounds of fuel will bring the back down just nice i think ......
New seats/ belts in
New seats/ belts in
Engine and trans set in car trans mount done engine mounts in progress
these ones show the turbo placement ..... dont worry the giant hole will be filled back in when its done
Front shot showing hole sawed bumper support and large intercooler
Few more shots of the interior slowly coming together:
[QUOTE=sleepybu] Mine felt more like 15lbs.
it's 7 lbs for just the armrest between the seats, unless you're talking about the entire console from the dash back.
tirefryin...i like the location of the shifter but how is the position when it's all the way back? love those seats too. mine sat up high in the rear also after i did the rearend swap, but mostly because the springs weren't rotated in the correct direction. put the car back in the air and rotated them 180* and the car sits much lower now. i'm getting ready to put on a set of rear coilovers to see how low i can get it shortly. keep us posted it's coming along nicely!
i have not taken the springs out at all they are still in the stock spot etc ... the car isstill sitting on a posi 7.5 waiting for me to finish building the 8.8 , the shifter is good its not too far back or anything .... any guesses what this car weighs?
#35
Here are some semi recent pics mores been done but this is some basic updates
Cold side / Blow off valve
A shot of the motor in the car with some stuff on top of it
Heres some self explanitory pictures:
Check out this BAD *** shift **** authentic ww2 pineapple grenade -i blow up alot of motors etc so thats the reason for the grenade ...every run ill pull the pin and hang on LOL :fear:
All my new front end goodies... thx to carlos at cvs for hookin me up with this bad *** upr chromeoly stuff/ coil overs etc
The diff parts .... 31 spline moser axles with c clip eliminators and a 31 spline strange spool
Look at the difference between the new axle and an old stocker
Torque box reinforcement kit for top and bottom also courtesey of upr/ carlos @ CVS
#38
Whats up with the k-member???
I thought you were going to use the stock one.Was there some sort of problem with the stock k-member,like getting motor mounts to fit or clearance issues???
What k-member is that for 4.6 or 5.0?
What motor mounts are you using?
#40
no i was going to use the stock k and it works just fine the motor is all in the car bolted down and i will probably drive it with the stock k for a while this one is a 5.0 k member and the mounts are solid that i built ....
