FS: 1996 Pontiac Formula WS6 LE2 GMMG TTII 315's black on black 6speed 400+ rwhp
SOLD!!! 11/9/07.
Well, Im going to regret this, but here goes nothing...
One of 524 1996 Formulas. 84k on the odometer, 2000 on the h/c setup that was done in June of 06.
Car put down about 404 rwhp and something like 388 rwtq. Im sure on the hp #'s, but not so certain on the tq. Ill upload the dyno sheet.
Car ran a 12.64 while it had a missfire. Why did I take the car to the track with a misfire? Because I was anxious to see what it would do and it was the end of the driving season (October) and I didnt want to take the car to the track in May since I was still on the stock 10 bolt. Made 6 passes and then the rear end said it had enough... have new 4.10 gears in there along with a Torsen unit.
First, THE BAD...
-Car will need a headliner. It is coming off ever so slightly right behind the drivers head.
-needs an alignment
-there is now a paint chip on the hood the size of a quarter that my dad put in there by accident while working in the garage.
-the passenger side headlight motor works, but the 'stop' guide thingy broke off
I drove the car to Kentucky in 06 right after the h/c and had no issues whatsoever.
A missfire did develop but that was due to bad plugs, but that is it. Car runs really strong right now with no problems.
EWP failed at about the 2300 mile marker but was replaced with a new one.
Mods are as follows....
Exterior Modifications:
-American Racing TTII's
-BFGoodrich KD's all around, 315/17/35 in the rear
-Baer Erdispeed+ brake upgrade
-Blackbird hood stripes
-!sidemolding
Interior Modifications:
Performance:
As of June 2006, the top end is all new. Basic setup consists of LE2 heads and cam. Car put down 400 rwhp, so thats about 465 at the crank!
Parts list...
Brakes and Wheels
-Baer Erdispeed+ brake kit w/drilled and slotted rotors
-Stainless steel brake lines
-American Racing Torq Thrust II's, 17x11 in the front and 17x11
-BFGoodrich KD tires: Front-275/40/17 Rear-315/35/17
Exhaust
-Hooker 1 3/4 longtube headers
-Off-road y-pipe with no cats
-GMMG exhaust with oval tips
Engine and performance
-Hypertech 160 degree thermostat
-Holley polished 58mm throttle body
-Delteq ignition system
-NGK R 5671A-7 plugs gapped @ .035
-Throttle body bypass
-MSD wires
-K&N air filter
-Optima red top battery
-LE2 ported, polished, milled heads
-205 cc intake ports
-Comp bee hive springs
-CM Retainers & 10° Locks
-Ferrea 200/1.56 Valves
-Impala head gasket
-Intake ported and polished to match heads
-LE2 cam, smilar to CC306
-ARP bolts
-Accel 36lb. injectors
-LT4 knock sensor
-CSR electric water pump
-Comp Cams 1.6 ratio roller rockers
-GM guideplates
-Chromemoly pushrods
-GM replacement lifters
-Cloyes double roller timing chain w/new sprockets
-Aluminum driveshaft
Suspension/Chassis:
BMR Lower Control Arms
-BMR LCA reloction brackets
-BMR Panhard bar
-BMR adjustable torque arm
-BMR chasis mount TA relocation bracket
-BMR front/rear sway bars
-SLP weld in subframe connectors
-Eibach pro kit lowering springs
-Hotchkis strut tower brace
Im sure Im missing some stuff.
The paint is in great shape.
Here are a few pics...
ASKING $12,500.00 OBO.
Car is located in the Chicagoland area.
Please give me about 2 days notice before coming out to see the car so that I can clean it. I've only put 80 miles on it this year and all it does is sit in the garage collecting dust.
Ill TTT this thread every once in a while. I cant access LS1tech at work, so Ill be responding during the evening hours.
Thanks, Greg
Added a few pics...
walk around video...
http://s64.photobucket.com/albums/h1...1020241MOV.flv
First, THE BAD...
-needs an alignment
-!sidemolding
Performance:
Parts list...
Brakes and Wheels
Exhaust
-MSD wires
-K&N air filter
-Impala head gasket
-ARP bolts
-LT4 knock sensor
-GM guideplates
Suspension/Chassis:
-BMR Panhard bar
Thanks, Greg
Added a few pics...
Sorry but I am not interested in trades at this time. I curretnly have a GMC Sierra as DD which I will most likely end up selling as well to possibly get a GTO as the only vehicle.
I really do NOT want to sell this car, but at this point in my life I need to focus on more monetarily responsible decisions... buying a house, getting married etc. I will regret selling this car, as I wanted to keep it forever, but there will be another car, another day.
Thanks!
Thanks!
First bump... TTT.
It's going to end up on ebay or autotrader.com soon. I'd rather sell it to someone who knows more about these cars and someone who'll take care of it as well.
About $7k was spent on it this time last year on the h/c and exhaust.
More pics...
Delteq has been relocated to the passenger side firewall, not on the valve covers anymore...
Idle of the car prior to being tuned at FLP...
1st start in about 6 weeks...
http://www.fquick.com/videos/cold_start/1142
The rear end going bye bye at MIM...
http://www.fquick.com/videos/Death_of_a_10_bolt/772
Thanks for the compliments guys... Ill definitely miss the car once its gone, but life happens.
I've spent a lot more than the asking price for the car, but as we all know this is not something we're out to do to make money on. We do it for the hobby and for the love. You're bound to loose money on modifiying the car. I did it with the intention of never selling it, but I need to do a few things with my life before I return to the car performance hobby.
Semi-odd question, but was this car running a dumped exhaust within the last month? I got flown by on Euclid going from Mount Prospect to Glenview about 2 weeks ago and it sure did look a lot like this car. If so, this was the very car that pulled me back into looking at domestics rather than settling with some foreign car.
Originally Posted by scrmnws6
^What road was this on?
I'm really bad at streets, but I saw the car turning right onto Euclid from the street right before the train tracks from hell. If you're a local, you know what I'm talking about.
Hmmmmm...I know I was driving it a little, just dont know if it was that area.
If it is, I want your car REALLY badly. It was my first experience with massaged domestic vehicles, so it for sure holds a special place for me!
Nope... mines not dumped. But yeah... domestics rock!
Keeping this up...
man thats a beatiful car, i remember finding it on cardomain as i was browsing at formula's one day, i saved a pic of it as "future car" on my pc, man i wish i had the money..... bump for a beatiful car
