Projector light Reject Mod:: How To!!
Old Aug 29, 2007 | 07:35 PM
Reject's Avatar
Default Projector light Reject Mod:: How To!!
Well the only thing that i didn't like about the new projector lights were those little led's on the side of the housing that killed the flow to the whole thing, so what i did was got them to turn off now. anyways it's super simple and you dont even have to open the headlights!!
You will first need to find a tiny sharp metel, i used the end of a spring i had laying around
Second you need to find which wires you are needing to reject.
The two wires that light up the LED's on the side of the headlight are these two
Right here is where you could clip off those two wires and be done with it making sure to just tape up the ends so that they dont short out.....or you could continue to take out the wires from the harness to be able to use them later down the road not needing to hake the wires up
If you wanted to try and keep the wires from having to cut them then continue on
you will need to disconnect the harness from one another, to do so you need to push down on the little tab that i'm pointing to with the tooth pick
note which two holes of the harness the wires i'm taking off, the two CLOSEST to the tab
what you will need to do is use your metel pick to push down on the little tab's holding the wire in place (the tab is located where you see it indexed in the center bottom of each hole)
push the tab in and pull the wire out.
These are the tab's i'm talking about
once they are both out tape them seperatly (as to not short out with one another) then tape then together around the main harness (to not get in the way when you install the headlight
plug it all back up.....
throw the headlights on the car..... wire them up how ever you wire them up....
BAM!!
Rejected LED's mod
simple enough huh!!
i just wanted to do a write up and have a mod actually named after me! what better mod to use than rejecting the side led's!!
anyways hope you enjoy
Old Aug 29, 2007 | 07:39 PM
Brian2006's Avatar
So basically this "write up" tells you how to not use a couple wires?
Nice Write up Reject
Old Aug 29, 2007 | 07:41 PM
Reject's Avatar
mmmhmmmm
rejected them fkkers!
Old Aug 29, 2007 | 07:47 PM
VIP1's Avatar
Copy & Paste Moderator
How about wire them into the turn signals?
I think that would look cool and should be almost as easy.
Old Aug 29, 2007 | 07:49 PM
Reject's Avatar
i thought about that but i dont use my turn signals so i'd never be able to see them, but yeah that would be super easy
Old Aug 29, 2007 | 07:57 PM
Brian2006's Avatar
Any particular reason why you dont use your turn signals? I never thought about that and that'd be pretty cool
Old Aug 29, 2007 | 07:59 PM
Reject's Avatar
fiiiiiiiine i'll wire them up tomorrow and put a video!!
Old Aug 29, 2007 | 08:02 PM
Blackbirdws6's Avatar
looks very nice. I will also say the turn signal mod would look real nice and def. be different. You don't use turn signals? lol.
-Brian
Old Aug 29, 2007 | 08:06 PM
Reject's Avatar
alright i'll do it tomorrow shouldnt take more than 10 minutes to do, and i'll include pictures!! lol
Old Aug 29, 2007 | 09:04 PM
SpdFrk1990's Avatar
Ok wire them to the turn signals but make them sequential .
Old Aug 29, 2007 | 09:32 PM
Reject's Avatar
meh i'll leave that to the thunderbirds
Old Aug 29, 2007 | 09:44 PM
NxLS1496's Avatar
thanks reject, ive been wanting a set but the led's on the side have kept me away.
Old Aug 29, 2007 | 09:51 PM
Reject's Avatar
yeah no prob, easy enough huh!!
Old Aug 30, 2007 | 02:14 PM
Reject's Avatar
slight problem guys i'm going to have to swap the headlights out to the stockers for a week and send these back, my cut off pattern on the passenger side was total crap, the shield inside the headlight was not curved right and instead of wanting to fix it myself i'm going to send them back to get a new set, so the blinker integration mod will have to hold off on my end for now. but for other's out there than cant wait and are average with wiring, it's very simple...
one thing i forgot to add to the picture below is to not cut the ground wire (black) on the picture it is tooken off but you must leave it connected or else your LED's wont work!!!
Old Aug 30, 2007 | 04:11 PM
ULTX's Avatar
i think it makes carrie look evil er
Old Aug 30, 2007 | 04:36 PM
Reject's Avatar
excellent
Old Aug 30, 2007 | 06:35 PM
The Guz's Avatar
Nice write up. I was going to do the same thing but I was to lazy to do it. I just wanted my projectors in. I will have to think about doing this now so I don't have the LED's on with the halo's.
Mike
Old Aug 30, 2007 | 06:39 PM
Reject's Avatar
yeah, the LED's just kill it when they are on all the time, if you do the blinker deal post it up here and a different wiring diagram if you used a diff one, i hope i can get my newer one's in fast to post a vid of the blinker mod
Old Aug 30, 2007 | 08:59 PM
TheLS1Kid's Avatar
Looks good man.
Old Sep 4, 2007 | 11:26 PM
6LITEREATER's Avatar
Just used this write-up... VERY COOL!!!! Thanks man!
