Projector light Reject Mod:: How To!!
btw, these headlights are complete crap. The plastic they're made out of is so brittle, every single bolt I've had to re epoxy back in there. It's been hell. Im trying the washer mod now with a 1/2 spacer, and the stock brackets don't fit,lol. I'm going to go mess with it some more. good luck to me
I did this mod:
https://ls1tech.com/forums/appearance-detailing/784192-how-fix-poorly-fitting-adjusting-projector-headlights.html
and used the stock bolts (from my stock headlights sine they were slightly bigger) in the holes and needed no epoxy.
EVERYONE who gets these headlights should do the fix I posted above or else you will have alignment problems...
I just got done(I'm quite pissed at these things though).
After grinding the brackets to clear, the one bolt that holds the headlight locked in, still would hit the housing.
I cut the bolts about 1/4 shorter to clear. With them adjust all the way up(top adjuster) they aim almost level enough to make me happy.
Will you guys right now go turn yours on for about 3-5 min and see how hot they get. I know they're supposed to run cooler, but they get really really hot. The housings on the backside, right above where the bulb goes in is too hot to hold your finger on for more than a second.
...would not recoommend these new headlights to anyone though, haahaha, htey're complete crap and caused me more problems than anything. Im almost tempted to just stick a HID bulb in my older halos. They were atleast decent.
They may have been a PITA but nothing looks more evil than the two halo rings coming on when I arm the nitrous
I'm a mechanic, so I'm not some retarded guy, lol, these just gave me tons of problems.
And they get so hot I was worried, but I guess if you guys don't have problems I should be fine.
THanks agina
I think he wanted an easy ticket or was just having a bad day.
Looks like once I get some projectors (not for awhile though) I won't be turning mine into signals, just disconnecting them.
https://ls1tech.com/forums/appearance-detailing/839656-halo-s-wiring-question.html
