Tons of LT1 performance parts!
Parting out this car... Had quite a bit of stuff..
T56 with new syncros, bearings, 3/4 steel shift fork... Comes with bellhousing and hydraulics. $1200 plus shipping or picked up
Mcleod clutch (nearly new) comes with stock flywheel $300 shipped
Power Tower Pro 5.0 shifter... $100 shipped
Spohn (Pretty sure) Chromoly red STB $60 plus shipping
Pro Magnum 1.6 rocker arms with guide plates and locks 7/16 stud... $200 shipped
Hardened pushrods $50
LT1 short block (needs new piston because the valve smashed it, have paper work on the motor for the piston weight, would be a cheap fix) cylinder wall is not damaged. Motor has scat rods in it... $390
Comp cam .547/.563 .220/.224 (with 1.6 rocker) $120 shipped
I know there is more but thats a good start.
PM me if interested. Prices are +shipping unless otherwise noted. I take paypal only for safety.
Thanks,
Doug
Thanks,
Doug
THe cam part number is 07-000-8 Comp Cams... What I posted is all I had as far as details on the cam at 1.6 rocker... it was on the build sheet for the engine that I got with the car.
