Drop 50 MORE lbs off the front! PICS!
I wasn't sure how it would end up, but I hacked away and started brainstorming for ideas to put it back together. With the help of some friends we did a number on it and MAN is it SWEEEEET!
Pictures really do all the talking. This front-end is completely removable in less than 5 minutes, bumper and all right off the front. Talk about engine swap friendly!
It's not quite done. I still have to add a thin sheet to tie in the lower bumper support and keep the air from trapping under the car.
The car should be near driveable in 2 weeks, so updated pics with the engine bay painted are coming shortly.
I might just do this now to my 93. Is it all bolted to the frame? I'd think that the bolts might vibrate out over time. What did you use to secure them?
The frame has nuts welded on the back side where I boxed it in. I will locktite them so they don't back out. The sides, inner fenders, radiator etc. will all have locknuts.
I'm not quite ready for the tube chassis idea yet, although it seems I'm rapidly approaching.
Just a note to anybody that would consider doing something like like. The majority of the weight in the front end (bumper skin, headlights, etc.) is actually supported by the metal coming down the side fenders. It actually takes very little to hold the nose up.
EDIT: I like how you also welded the factory fuel line hole shut.
@ the point you're at, I would seriously run a tube off the 10 pt thru the firewall, across the top of the shock tower and then cut the shock tower out. It would to alot for rigidity of the frame, what is left anyway, and then you could do like 93's car and cut off 99% of the shock tower. Use 90 degree bends there though, it would be stronger
I will do a write-up but it's going to take me some time to put together.
Wow ... nice work
