240sx+lsx=cool,but add T76 and sy/ty=Nuts?
The simple run downgoes like this, 5.3l for now ( forged aluminum 370 over the winter
) T76 for now (80-88mm over the winter
) 4l80 stick shift to syclone tranfercase to s10 front differential, and infinity q45 rear. also I plan to keep it under 3000lbs Its a bit more complicated than that but thats the basic plan. Some body is probably asking them selves why would a person do this? I want my car to be all purpose. A car set up launch hard typically sucks when when you ask it to turn hard. and the inverse is true. Ask a hi powered 2wd car to accelerate hard from a roll and what do you get? smoke and rubber, fun but not so effective.
Most of the hard parts have been purchased and are in my garage the big variable left is the the torque converter. Also drive shafts still need be made. I'm thinking a 5 clutch vigalate around 3500 stall. For road racing run it locked in 2nd-4th with a button to unlock for down shifts (sort of a poor mans sequential) for drag racing run it unlocked I'm thinking I can get the best of both worlds. 4 gears should be plenty for a turbo motor and my gear will give the car a theoretical to speed of 206mph. with a goal of around 650 at the tire it should be a gear limited speed.
thats all for now here are some pics of the car, the old sr20det setup and the progress so far. I still have a long way to go.
I'm waiting for the 4l80 to sy/ty transfercase adapter and a 32 spline input shaft for the transfer case to get the awd up and running.
the front sub frame has bee taken out. the engine has been mounted as a stressed member of the chassis. no rubber or poly anywhere. the engine bolts in and with the two very stout mounts and becomes the link between the left and right frame rail. the axle solid mounts to the motor mounts. on the right it uses the stock mounting ears on the axle on the left its uses the three bolts you can see in the pictures. (does that make sense?) I will try to get better pictures soon.
I am a bit worried the the axle is now the lowest point but it still hangs no lower that a typical bodykit front bumper so I should be fine. (plus s10 parts are everywhere and cheap.)
Are the diff ratios the same you ask? no. before I get a lesson on why it wont work remember that I need the diveshafts spinning the same speed not the cv axles. tire size will make up the difference. with that factored in drive shaft speed will be less that 1/2% difference. that is not enough to cause problems. (when you drive in a circle drive shaft speed difference is more than that)
the car already has an j30 rear end and z32 hubs so that should not be a problem the front will use s-10 hub assemblies re drilled to 5x41/2 bold pattern or ford ranger hubs. yes s10 axles will fit in a ford ranger hub. with a little work) who would have thunk it huh? (ranger hubs are 5x4/12 like Nissan)
I'm currently in design phase for the front control arms. I plan to get the roll center back where it should be.
Second - I was asking, because some people might not realize to make the wheels spin at the same rate is important - don't ask, but I've seen too many people blow their diffs that way.
Third - pics of all this jibber-hootie going on in your front wheel wells. Mainly I'm wondering how it all fits together.
Again, good luck, I hope it will run as you want it to.
PS. are those rivets in your strut towers?
The trans, transfercase, and front axle has held up to 8's for the sy/ty boys, and that rear diff is near indestructible so i don't think I'll be breaaking many parts
the research has taken months.
I need to sign up for the sy/ty boards I'm sure some people there would be interested to see something like this.
