lt1 finally runs 9s
lt1 finally runs 9s
went to steele, al today and finally got in the 9s. dont get to run 1/4 that much. 1st pass was 10.02 second was 10.00 and finally 1.429 60ft 6.33@110.1 8th and 9.91@136. it had ran a 10.02@140 last year. mph was a little slow today.
9-Second Club
Your times are almost exactly what I went a week ago. The DA was from 200' to 400' all day, but I was spinning badly. I had lowered the rear, narrowed rear end and mini tubs. Finally got it hooking last pass this weekend with a 1.312 60', but the DA was up to 2000' this time, so it only went a couple 9.96s at 134 mph. Also went a 10.03 & 10.04 before it finally hooked. Had to go back to bias tires, with the radials it wouldn't touch the ground.
thanks guys. car has a single stage dry kit. jetted on 200hp. the kit was originally an nos off of a mustang. it comes with the built in fuel psi. reg. i swapped the first solenoid for a cheater and removed the 2nd and replaced it with a fml/fml connector i got at homedepot. the nozzle would only flow 150hp so, i drilled it out. with n2o on it holds 55-60psi going down the track.
car is low budget. the dry kit is what i had. the car still has the factory heads with stock valves(1.94x1.50). they are ported by a friend but have never been flowed. cam is a 230/236 113 lsa comp xfi. factory intake and fuel rails. i ported the intake myself but didnt really seem to pick up much. 1.6 roller tip rockers.
9-Second Club
Originally Posted by TwoFast4Lv
Nice work around. BTW Guys LT1 dry kits do not work like LSx dry kits We bump fuel pressure to get more fuel
Always good to see the LTx cars going again!
Hey Ed are you saying the radials were to much tire or not enough?
the car has never been on a dyno so, i have no ideal what hp it has. thanks for the props again guys. UPDATE: ran at an 8th mile track last night(crossville, tn) and had a new 8th mile best of 6.28@112.8 with a 1.45 60ft. the car hooked and then unloaded the tires and spun a little. but it only ran a 6.33@110 on the 9.91 pass a couple weeks ago. hope to run some 9.7s when i go back to a 1/4.
9-Second Club
Originally Posted by paulgto
i have a stock 4L60E what do i need to do to it to run 9s or should i just get a power glide?
Good luck, Ed
