Need help identifying Holley carb
A friend of mine gave me a 4 barrel holley that he says was either a 600 or 650 double pumper. I wanted to find the exact model of the carb but have failed. I found the following numbers on the carb
List-6708-1 0199 . I also see 7445, 8672, GR 4950
Any ideas of what carb this could be?
there is a holley list # pdf catalog available somewhere in their site, 22 pages.
page 7 lists R6708-1
model 4150 650cfm,
renew kit 37-1539
trick kit 37-933
needle & seat 6-504
primary main jet 122-542
secondary main jet or plate 122-85
power valve 125-65
pump nozzle size primary 0.025
secondary nozzle size 0.037
primary bowl gasket 108-92-2
pri metering block gasket 108-91-2
sec bowl gasket 108-92-2
sec metering block gasket 108-91-2
venturi diameter primary 1-3/32
venturi diameter secondary 1-9/16
throttle bore diam primary 1-1/2
throt b diam secondary 1-3/4
your pic shows mechanical secondaries. if it were vacuum secondaries it would have a vacuum secondary diaphram mechanism like this
model 4150 650cfm,
renew kit 37-1539
trick kit 37-933
needle & seat 6-504
power valve 125-65
A double pumper is I guess a nick name for a Holley with mechanical secondaries.
Plus if you open the throttle by hand and all four open, it's a mechanical secondary carb.
Plus looking at the pics, yes it is mech sec.
Now you know three ways on ID'ing one.
carb numerical listing, page 7
http://www.holley.com/TechService/Library.asp
also, specification manual for every model
http://www.holley.com/data/Products/...99R10015-1.pdf
thanx for the help. I cleaned the carb last night. I will be doing a motor swap this weekend and slapping on the carb. Then depending on how the carb behaves I will order the rebuild kit.
Good luck!
That carb was built specifically for Chrysler by Holley for the 1970-72 C Bodies. (Polara, Monaco,, Imperial). Not the easiest to find parts for, but not impossible.
1) Used on the 70-72 Chrysler Imperial 440 engines with automatic transmissions hence the Chrysler kick down linkage shown in these pictures.
2)Only Tech data that Holley had can be found here. (It's a PDF file with float levels, choke settings, etc. No CMF, jetting, or Venturi diameter data.)
Have some friends in the local MOPAR club looking for data, but they've come up empty-handed too.
