Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Best streetable SBC intake manifold?
Old 12-07-2009, 03:33 PM
LT1
LT1's Avatar
Default Best streetable SBC intake manifold?
What is the best carb intake manifold for a small block Chevy. Something that can make big power and streetable. I'm thinking of getting a intake manifold that will support a lot of power for future modifications (maybe 900hp or more). I would appreciate anyone's suggestion, thanks.
Old 12-07-2009, 03:41 PM
supermouse4's Avatar
For good streetability, the Edelbrock Performer RPM Air-Gap dual plane is outstanding, but with what it sounds like you might be doing, go with a Super Victor or Victor Jr single plane.
Old 12-07-2009, 03:56 PM
LT1
LT1's Avatar
ahh i see, so how does the single plane and dual plane affect the power curve?
Would the Victor hurt performance if you are making less than 350hp? I was thinking about getting big intake and run it till i get my other engine built. I don't know if this is a bad way to go.
Old 12-07-2009, 04:07 PM
In-Zane Moderator
ZONES89RS's Avatar
It is like this, if you have a small stall about 3000 RPM or less, the RPM air gap is the right one, if you are going over 7000 RPM or stalling above 3500 RPM where the low end doesnt matter, the Vic Jr is better. And for all out, the Super Vic is the best.
Old 12-07-2009, 04:22 PM
LT1
LT1's Avatar
Then it looks like the Victor intakes are for top end power. Just read edelbrock website found out they make power at 3500 to 8500+ rpm.
Thanks Zones89RS and Supermouse4
Im gonna keep researching see what else i can learn, before making the purchase.
I saw the Toker II intake how does it compare to the Air-gap? More off the line power? Is it possible to make big HP numbers with a Toker II?
Would Super Vic be ok to run on Chevy 350 as temporary intake to daily drive? Im guess it wont because there wont be low end power. Has anyone done this? is it real bad and not worth attempting?
Old 12-07-2009, 04:37 PM
kenSS's Avatar
i would not go torker II. Go air gap for now and spend another 250.00 dollars when the time comes for the victor.
Old 12-07-2009, 04:42 PM
JUICED96Z's Avatar
Vic Jr for moderate power.... Super Vic for a lot of power.......... I think it is safe to say that with 900hp the Jr will choke it out.
On the 350 question........ if you plan to go with a Super Vic at some point get it and try it out.... if you don't like it put it on the shelf for a while....... you can find used Vic Jr's out there and I am sure you cna also find used Super's also.
The air gap's though are a tdime a dozen these day's and can be found at almost any swap meet. For temorary use I would get the cheapset intake possible that works for your combo...
When making power on a small block based motor I would not use anything but a Super Vic unless I went sheetmetal but even there often the added cost of the sheetmetal intake is not worth the added power.
Old 12-08-2009, 02:25 AM
RedGut86's Avatar
I agree, you can find them cheap on the worlds largest swap meet too. Ebay.
It sounds like, as others have suggested, that the RPM Air Gap is your best choice for the current motor or a street thumper.
Once you build that big bad motor you'll want to go SuperVic if you are really shooting for high-rpm 900hp, probably ported to hell at that point too.
One thing though, your handle is LT1? Everyone here has been talking gen1 SBC which you can definitely make these intakes (there is an LT1 RPM air gap) work with your motor but there are some mods (blocking the thermostat housing outlet, closing the distributor hole, and some re-drilling of the holes for bolting the manifold to the heads. If this is for the firebird, disregard.
Old 12-08-2009, 02:27 AM
RedGut86's Avatar
On a 350, I would think the Victor would be a dog down low. So if you are talking a stock 350 or mild 350, I wouldn't think it wouldn't be a very fun manifold on the street.
Generally, dual planes make more torque down low. Single planes make more torque up high (horsepower).
Old 12-08-2009, 02:56 PM
1 FMF's Avatar
http://www.musclemustangfastfords.co...ade/index.html
http://www.popularhotrodding.com/eng...ake/index.html
Old 12-08-2009, 10:55 PM
LT1
LT1's Avatar
Awesome thanks for all the info and help. i ordered the Edelbrock RPM Air-Gap.
I'll have to buy the Super Vic later for my other build.
Old 12-09-2009, 03:42 AM
RedGut86's Avatar
I think you are gonna be pleased.
Is the motor it is going on a stock 350 or modified?
Old 12-09-2009, 06:32 PM
LT1
LT1's Avatar
well i was going to use the stock 350 but decided to tare it down and start building it and keep the 307 engine thats in there now. So i'll be running the RPM Air-Gap on the 307 for now. Anyone know what temp. thermostat i should use?
UPS just dropped it off today.
Old 12-09-2009, 06:37 PM
tittan1500's Avatar
So your asking basic ? about intakes and making under 350HP but your shooting for 900HP
I think you should buy a new intake in a few years when you get to that power level. If you are serious about the 900HP than the $200 for a new intake will be so insignificant to your total budget required for the big HP build.
Old 12-09-2009, 06:42 PM
LT1
LT1's Avatar
Yup your right tittan1500 thats the conclusion i ended up coming to.
Initially i thought maybe i could by a bigger intake and hang with it till i got to the point of using it, but ends up being a bad idea. I would have low performance and crappy driveability just cause im trying to take short cut.
Old 12-09-2009, 10:00 PM
RedGut86's Avatar
You made the right decision. (That was damn fast too!)
I know that SuperVics on some motors can still thump down low well enough, but on a 307 that would've been rough.
Old 12-10-2009, 12:22 AM
In-Zane Moderator
ZONES89RS's Avatar
I use a 185 T stat on all my engines.
Old 12-10-2009, 02:02 AM
LT1
LT1's Avatar
Yeah it was fast, they shipped it from Nevada which is 1-2 days shipping to SoCal.
Do i have to run the O-ring and thermostat gasket or just one of them?
Old 12-10-2009, 03:43 AM
RedGut86's Avatar
I believe just one of them, but I've heard bad things about the o-ring so I always just run the gasket. I have to admit, I've never tried the o-ring so it could just be internet chatter.
Nevada, sounds like Summit. Man I love them.
Old 12-10-2009, 02:10 PM
NemeSS's Avatar
i ran all over the place with vic jr. on my sbc
Quick Reply: Best streetable SBC intake manifold?
