Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Distributor an coil help
Old 12-18-2009, 11:45 AM
Pseudonym's Avatar
Default Distributor an coil help
Which distributor and coil would you reccomend for a 383 sbc? I need to get a new one because I have been disappointed with the accel distributor and coil that I have. It is for a street car.
Thanks in advance, Al
Old 12-18-2009, 03:02 PM
cambirdracing's Avatar
Depends what kind of room you have.
MSD makes some really nice HEI style distributors with the coil in the cap and some with remote coils.
Start here:
http://www.msdignition.com/info.aspx?taxid=8&taxid2=118
Old 12-18-2009, 04:58 PM
Pseudonym's Avatar
Thanks cambird. It is in a '68 Camaro so everyone has some idea on what Im working with in terms of room.
Old 12-19-2009, 08:20 AM
Pseudonym's Avatar
Anyone else?
Old 12-21-2009, 08:47 AM
pancherj's Avatar
What's your specific problem with the Accel? Is it their HEI version? Are you running high compression or using an MSD (or other) box?
Old 12-21-2009, 06:46 PM
Pseudonym's Avatar
My problem is that they keep burning out. I've been through 3 distributors, 4 coils, and 5 modules. I'm changing a part about every 4 months. It's the billet electronic, not HEI. running about 10:1 cr. No box and its got an accel super coil, taylor super spiro pro wires, with accel shorty spark plugs. I can't get model numbers now because the car is covered in snow
Old 12-22-2009, 06:15 AM
I am not sure about the voltage requirements, but you might have to much voltage going to it. I know the Mallory with the electic eye inside requires 6 volts and if you put more than that you will burn it out. I have done that twice about 20 years ago. Since I figured that out, I have not burned one since. and this is on the same dist.
Old 12-22-2009, 08:49 AM
Pseudonym's Avatar
My dad checked and double checked, he said voltage was fine. This is the first distributor we are having a problem with. I think we are going to replace it with an msd or a pertronix flamethrower. Does anyone have experience with pertronix? We have used msd on another small block chevy, and a small block ford with no problem, just looking to see if there was something better.
Old 12-22-2009, 09:01 AM
Probably not going to get much better than a MSD.
Old 12-22-2009, 08:42 PM
Pseudonym's Avatar
Didn't think so, but Im going to be in Ohio from the 26th-30th. I will be about 15 minutes away from the Summit store so I figured I would ask before I buy. Thanks alot cambird.
Old 12-23-2009, 06:20 AM
No problem, have a safe and fun trip.
Quick Reply: Distributor an coil help
