Low Dyno.. What's Wrong?
Ok, so the crate motor was supposed to make 620 hp/tq crank...
Block
4 Bolt Main .060 over block
Two piece rear seal, drivers side dipstick
Square and parallel decked
Align honed main bearing bore
Cylinders honed on computer controlled machine to within .0002
straightness and roundness
Cylinders are sonic tested for thickness
Rotating Assembly:
New SCAT forged steel crankshaft internally balanced
New SCAT 4340 forged H-beam connecting rods
150,000 psi rod bolts
Probe forged flat top pistons
Hastings moly rings
Rotating assembly balanced to within 2 grams
Melling high volume oil pump
Hydraulic roller cam
Jesel shaft rocker system
Cylinder Heads:
AFR aluminum rectangular port cylinder heads
305cc runners and 119cc chambers
1.509 dia. Valve springs w/ damper Hardened retainers & keepers
2.25 swirl polished intake valves
1.88 swirl polished exhaust valves
Comp cams hardened push rods
Jessel rocker arm system
Edelbrock performer RPM airgap intake manifold
10.0 to 1 compression
Milodon cad plated oil pan
Brass freeze plugs
Professional Products harmonic balancer
TRANS is a Th400 with 2300 Holeshot converter
REAR is a 12 bolt with 3:08s
3rd gear at 6000 RPMs was 139.1 mph, so I would figure it's about 8% slippage on the converter. I plan to have an FTI custom built, but could this converter really be the reason for me being so low on power?
All input welcome
Block
Rotating Assembly:
Hastings moly rings
Cylinder Heads:
Brass freeze plugs
All input welcome
In-Zane Moderator
Man, you need to know one thing, a automatic can give some WAY off readings, i have seen cars make 450 RWHP out of a big block but still nail down low tens to the wall, meaning the readings were fals, only use the dyno for maximum tuning purpose and not for the actual power read out, use a calculator and the track to get the estimate with your MPH and race weight, ti is WAY more accurate for me.
-Z
-Z
-Z
-Z
two things stand out to me. the first is the flat top pistons, flat top pistons and open chamber heads at 119cc usually result in low compression. i would think it needs a small dome to achieve 10:1. second is the rpm i would think an AFR headed big block with a roller cam would turn 6500-7000 rpm and the pull stopped at 5800. i would double check the timing and look at all eight plugs for clues. hopefully someone with more knowledge will chime in here.
To the OP your A/f is way down dipping below the 12's in the middle of the pull and barely above 12 at the peak of the pull. It needs to be a bit leaner and you might see more power.
The motor is a crate motor. (Mostly wanted a warranty honestly..)
http://www.blueprintengines.com/popu...specs&pc_id=64
496 chevy, 8-71 blower, 12 psi, 4l80e, 3.50 rear gear, heavy tires, steel wheels.
disappointing chassis dyno #'s = 520 rwhp, 580 rwtq
3800# (plus driver) => 10.62@127 (foot brake, 91 octane, hacked stock converter)
I don't claim to be any sort of chassis dyno expert, but I have a suspicion that if you put the same setup with 4.56 gears would see significantly higher numbers.
Dont put much stock in the rwhp dyno numbers....A TH400 is a horsepower killer, as is the mechanical accessories etc...All that really matters is how it runs....
When I dynoed my 496", we gave it the best possible conditions to make good power....(no accessories, no water pump, hot oil temp, cold water temp, big 2" shop headers with no exhaust, dyno carb hat, well ventilated dyno room etc...) mine made a corrected 657hp/675q.
But in the car I have full mechanical accessories, smaller headers, full exhaust, no carb spacer etc, Th400 w/10" converter, IRS rear end etc...so I only expect about 430hp to the wheels or so....a total turd right???
Last weekend I made one soft pass and it ran 11.14@122 with only a 1.69 60' at 3730lbs then got restricted to 1/8 mile....I made 3- 1/8 mile passes and it kept getting quicker...ended up at a 7.05 1/8 at 99.36mph....
This is a heavy, stock suspension, highway geared, weekend cruising 71 Vette with AC on a 255/60 drag radial..... No one would suspect it being even remotely fast....yet if I was to dyno it I would have been very disappointed with my low-mid 400s.....
Get it to the track....you'll be happy if the motor really made 620hp at the crank...
I doubt that thing is 10:1 with flat tops and open chamber heads. your lucky if its 9:1 really. (not trying to be a dick)
I dont understand why they have all that duration and then a 112 LSA on a carbed motor...no sense except to have a smoother idle....dumb.
What size are the headers and carb?
I'd like to see some 2" headers and a nice 850 DP Holley on there.
and some gear.
Chad
