How Many L31 383s are out there??
Well If I really wanted a lowend TQ monster for towing/Moving the Big ole Tahoe around. Well what setup would you chose to do? Get a 383 short block and have the Vortec heads milled/clean the stock intake manifold/port the TB and get a TQ biased cam?
I have a 383 Vortec to go in my Tahoe, but the problem is the fuel injection setup on them. The stock spider won't supply enough fuel for a stock cube motor with a cam, much less a 383 with a cam. The easiest solution is the marine intake since it uses EV6 injectors and rails instead of the shitty spider setup.
Thats pretty much all the informance you need about it. Its the intake that comes on the GM L31 marine motor.
