how much power should i make
i will be putting my car on the dyno this friday and i wanted to see what kind of power u guys think i will make..
i have a 70 350 bord 40 over
camel hump heads milled to 60cc cambers
comp 268 cam
hype speed pro pistons
dart rpm air gap intake
edelbrock 750 carb
1.5 roller rockers
scat fordged crank
black powdered rods
shorty headers
it is a stock stroke
the calculated compression is around 11.5:1
the only accessories are the alternator and water pump
the head and intake were ported to match gaskets and polished
the motor is in a 88 rx. im running a t5 world class trans an aluminum 1 peace drive shaft and the stock RX rear
thanks for the time guys and let me know what u think
comp 268 cam
edelbrock 750 carb
1.5 roller rockers
scat fordged crank
black powdered rods
shorty headers
Thanks man I am starting to look at sum bigger cams now how much timing do u think I can run I have it around 12 base 38 advance I was also thinking about putting on a small shot 75 or 100.
Cylinder heads are the best bang for your buck I think. Nothing super fancy but a nice set of vortec heads or a a cheap set of 180-200cc budget heads. Bolt on's and more camshaft will get you some more power but a set of heads will get you more power than you bargain for and leave room to spare for more camshaft and good things like that. I actually have a rather nice set of vortec's for sale if anyone is interested. ought to put you over 350whp with some good tuning.
