Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
85 IROC TPI, no injectors on start up, please help
Old 04-13-2011, 06:00 PM
LS1-450's Avatar
Default 85 IROC TPI, no injectors on start up, please help
Whe have confirmed grounded power into the 85 PCM for the injectors. No injector pulse while cranking. We get full & constant voltage from the PCM, to injectors, after starting the engine w/ starting fluid. VSS unit is not w/ car. Is there a tach signal or some signal that the 85 PCM requires from the missing VSS unit that is causing the problem? We have confirmed all other wiring. As noted, engine will run on starting fluid. Please comment.
Also, we tried (2) separate 85 PCM's resulting in the same no injector pulse issue. Am not aware of any VATS associated w/ an 85 PCM.
Old 04-13-2011, 08:24 PM
LS1-450's Avatar
Checked injector resistance & it's good. Checking ignition switch circuit. Will add VSS module. SES light flashes once w/ key on & then goes out. If ignition switch is OK & VSS has no effect on injector issue, will change ignition control module.
Old 04-15-2011, 10:44 PM
IrocZTransAm's Avatar
Had the same problem with my 85, and your right, no VATS for these years. I changed my ignition switch and bingo was his name-o. Only started with starting fluid as well. Are you getting voltage to the switch? Coil? Pick up? Etc.. I know these are newbie style questions but gotta cross your T's and dot your I's.
Old 04-16-2011, 03:30 AM
LS1-450's Avatar
Thanks for the repy. Switch is testing good. Went w/ a new ignition control module that came in last evening. Will install over the weekend. Am hoping for the best.
Old 04-16-2011, 09:28 PM
Cool let me know, it's always nice to hear about TPI problems as the gremlins in those cars make for a horror story that would make Stephen King cry. I got many bugs to work out on mine sadly.
Old 04-17-2011, 06:27 PM
LS1-450's Avatar
It now starts while using the new ICM. However, there is a miss. So, we are going to change the ignition switch next & then look @ the 02 sensor. Something tells me that the ignition switch is a better candidate than the 02 sensor because the replaced ICM worked in the donor car before it was pulled & installed in this car. So, something on this car caused it to fail. Will post again once new ignition switch is installed.
BTW, also through an SES light. We have an OBDI cable & will try to read the code(s), as well.
Old 04-17-2011, 06:46 PM
indyboom's Avatar
Your o2 may need replaced but its not your issue. O2s dont provide feedback till like 400 degrees.
Old 04-18-2011, 01:13 AM
^this is correct.
What has been replaced ignition wise?
Old 04-18-2011, 01:10 PM
LS1-450's Avatar
Only thing remaining is the ignition switch. Everything else is brand new. Once the ignition switch work is done, we will know.
Old 04-19-2011, 07:43 PM
LS1-450's Avatar
Ignition switch did not fix. It's as if the computer & distributor are fighting each other for control.
We are scrapping the TPI or (POS) as we've re-named it. Looking for a good working 650 4 barrel carb & aluminum intake manifold if anyone has 'em reasonably priced. We have a carb vacuum advance dist & are making provisions for controlling the transmission.
Old 04-20-2011, 01:09 PM
LS1-450's Avatar
Found carb & intake. Should have everything installed within a week or so.
Old 05-02-2011, 01:28 PM
ringmaster72's Avatar
Quitter, LOL. I have been there with TPI. Got so tried of fooling with it, I went ahead and got a Holley Commander 950 and Stealth Ram. **** on TPI.
Old 05-02-2011, 03:08 PM
LS1-450's Avatar
Yah, it was a matter of not wanting to keep throwing money @ something that may have been un-fixable.
Old 05-02-2011, 06:44 PM
I dont blame you, plus it is a nightmare to work on.
Quick Reply: 85 IROC TPI, no injectors on start up, please help
