Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
350 chev won't run when tach wire is plugged into dizzy what's wrong?
Old 04-20-2011, 10:07 PM
ilovev8s's Avatar
Default 350 chev won't run when tach wire is plugged into dizzy what's wrong?
My buddy has a 1980 z28 that had an aftermarket tach, he is hooking up the original tach but the car won't run when the tach wire is plugged into the dizzy, the car will run perfect when it's unhooked any ideas whatss wrong he wants his tach functional
Old 04-20-2011, 11:45 PM
ilovev8s's Avatar
bumpp
Old 04-21-2011, 05:58 AM
cambirdracing's Avatar
He is hooking it up the the negative side? The tach might be bad and shorting out. Or he is trying to hook up the wrong wire.
Old 04-21-2011, 06:59 AM
ilovev8s's Avatar
He's hooking it up in the right spot and I assume it's the right wire, does the tach have the wire going to the dizzy and a wire going to ground? I don't understand why the car wouldn't start with it plugged in
Old 04-21-2011, 04:02 PM
You can Google 1980 Z28 tach wiring diaghram and find out more than I really know about this subject. GL
Old 04-23-2011, 11:25 AM
LilJayV10's Avatar
Either he is putting in the wrong spot or there might be something crossed in the dist. I'd pull the cap and see where the grounding metal tab is. If doesn't run with the tach plugged in it has to be grounding the whole thing out.
Old 04-24-2011, 06:47 PM
indyboom's Avatar
what the hells a "dizzy"?
Old 04-26-2011, 09:38 PM
LilJayV10's Avatar
It's the distributor. LOL.
Old 05-02-2011, 04:12 PM
Awake455's Avatar
If it's an HEI I suspect he's plugging it into the wrong terminal. Needs to be on the other side.
Been a while since I had an HEI tho.
Quick Reply: 350 chev won't run when tach wire is plugged into dizzy what's wrong?
