Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > Small Block & Big Block Chevy Specific
Sign in using an external account
Register Forgot Password?
Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Thread Tools Search this Thread
Old 02-19-2012, 05:41 PM   #1
Garage is empty, add now
DSRE's Avatar
Trader Rating: 7
Default Chevy 388sb dyno results
I'm Derek and i thought i'd show the results from a 388 sbc i just finished and dynoed thats going into a 86 camero for street/road race style driving, I try to build engines that make excellent average power in the rpm range they will be used in without breaking the bank
sure i could have made even more power with a bigger cam and Ported Victor Jr but i felt i could make a more user friendly setup with the parts we used fwiw
First we started with a 89 2-bolt one piece rear seal block
Fully Machined it, -.005 deck height 4.06 bore set main and rod clearance to
.0025 with ARP main studs
we then ported and blended the oiling system transitions in the block and rear cap.
Ported Melling m55 with Canton Road Race Pan and pick up
We used a Scat LW 3.75 stroke 9000 cast steel crank and 6.0 scat pro stock 4340 rods bushed with ARP 8740 cap screws
For Pistons we used Probe FPS forged 2618 alloy Flat Top 2vr pistons at 320$ a set there is no reason to use cast stuff anymore!
compression is 11.08:1 with 4cc valve reliefs, 67cc chamber .035 Quench
moly 5/64-5/64-3/16 rings standard tension nothing fancy
Fully Ported Edelbrock Perf RPM Heads flowing 280cfm at .600in 237ex at .600 with pipe on a 4.06 bore SF600 190cc intake runner
Edelbrock springs, GM LS7 lifters, billit dbl roller timing set and smith bros .083 wall 5-16 7.300ol push rods
trick flow 1.6x7/16 rr arms
Comp XR282HR 230-236 .540 .550 110lsa 106.5ilc
Performer RPM intake Non Air Gap, Modified Plenum and Port Matched
Holley 750cfm Ultra HP, MSD Dizzy, Hooker Headers 1-3/4 primaries
I Wish we went with the 850cfm Ultra, we had about an 1.5" hg of restriction so i'm sure it would have cranked out more with a bigger carb but either way i'm happy and so is the customer most importantly!
i'm trying to upload the dyno sheet but i'm having trouble, overal we made 493hp at 5800-6000 and 491tq at 4800 and average power at 425hp 475tq, not bad for no afr heads or using a bigger cam, superflow dyno, there is easily 500hp there and if i had more time i think she has aprox 510hp 500tq but still for not Spending much time tuning i'm happy, i'll post the video too, thanks
Derek
__________________
DSRE just another engine guy
personal ride 06 silvy 4x4 383lsxt
11.4:1 Custom cam 231-235 .624-.624-113lsa
LS7rollers sb push rods HS 1.7rr
DSRE Dart 229cc HP heads 325cfm at 6
Ported TBSS intake 90mm dbw tb
1.75" lt's 3400stall
old combo 444rwhp 424rwtq New combo tba
DSRE is offline   Reply With Quote
Old 02-19-2012, 05:42 PM   #2
DSRE's Avatar
Trader Rating: 7
__________________
Old 02-19-2012, 08:12 PM   #3
Trader Rating: 0
Nice power for a inexpensive build. Good job!
topend is offline   Reply With Quote
Old 02-20-2012, 02:05 PM   #4
Trader Rating: 7
not bad at all
__________________
02 gmc rcsb 4.8 auto 3.73's 31's
70 Nova (Barney) 355, carbed, juice, th400, 3.8k verter, 12 bolt..11.89@113.66 1.70 60ft All motor 320rwhp 306rwtq
2005 GSXR 1000....its yellow.. -1, pcIII, yoshi tr-s.. 11.0@137 spinning in 2nd and 3rd (yes spinning) 148.5rwhp
1dirtybird is online now   Reply With Quote
Old 02-20-2012, 04:39 PM   #5
Trader Rating: 0
Very good numbers for a budget build!
Paul Huryk is offline   Reply With Quote
Old 02-20-2012, 06:15 PM   #6
DSRE's Avatar
Trader Rating: 7
thanks! much appreciated! it should rock that camero pretty good!
__________________
Old 02-21-2012, 04:12 PM   #7
Trader Rating: 0
I just remembered that your engine put out similar output #'s to the 383 that was built in the John Lingenfelter SBC book.
Old 02-21-2012, 06:33 PM   #8
DSRE's Avatar
Trader Rating: 7
I'll Take that as a Compliment! Lingenfelter was a big influence on me!
here is a link to my facebook page with the dyno sheet fwiw
http://www.facebook.com/pages/DSRE/224504460916792
__________________
Old 02-22-2012, 05:39 PM   #9
Trader Rating: 0
Indeed it was a compliment...
Old 02-23-2012, 03:17 PM   #10
Trader Rating: 7
Hey did you port the heads yourself? I ask because the low and mid lift #'s must be great.
__________________
Old 02-26-2012, 05:49 PM   #11
DSRE's Avatar
Trader Rating: 7
Yes i do all my own Port Work
here is what these flow, i wanted to see if i could get a set of e heads near an afr 180-195 head and i think i got really close, if i used thev bigger 236-242 cam i would have a better comparrison to some afr head dyno sheets
.200 155in 123ex
.300 208in 170ex
.400 261in 205ex
.500 273in 226ex
.600 280in 237ex
__________________
Old 02-27-2012, 01:03 PM   #12
Trader Rating: 7
Very impressive low lift numbers, how much do you charge for porting lol
__________________
Old 03-20-2012, 09:50 PM   #13
2001 Pontiac Trans Am
kingd_202's Avatar
Trader Rating: 7
What kind of gas mileage can I expect out of a motor like this behind a muncie m22 with a 12 bolt, 3.42s in a 3700lbs A-body? 20's?
__________________
1970 Chevelle ss-Broke down piece of $hit!!
1999 Trans am m6-Project!!
2001 Ws6 a4- Garage Queen!!
2002 SOM WS6 a4-Race Car!!
1992 Prelude SI-Embarrassing POS DD!!!
kingd_202 is online now   Reply With Quote
Old 03-20-2012, 09:52 PM   #14
kingd_202's Avatar
Trader Rating: 7
Also average rwhp? Is there a big loss in power going turbo 350 or 400? I brought up this thread at work, and they all started laughing at me claiming thats how much it makes to the motor and expect to loose around 100hp going thrue a turbo 350?
__________________
Old 03-21-2012, 04:10 PM   #15
Trader Rating: 7
my nova gets about 15 on the highway... it really makes 340ish to the tire with the new exhaust. i cruse anywhere from 3 to 3.5k
3.8k converter 4.10's and a th400... i run a 275/60/15 m/t dr (28 inch tall)
expect 20% and it goes up as you make more power through an auto, that is due to fluid copuling loss
__________________
Old 03-21-2012, 06:04 PM   #16
DSRE's Avatar
Trader Rating: 7
Yeah PM sent but we will know soon, The last 383 i built like this did 412rwhp 437rwtq through a 2500 stall 3.42 gears and light weight wheels on a mustang dyno but it had less cylinder head and slightly smaller cam so who knows, i just use the dyno for tuning and testing the track is where the bullshite stops lol
__________________
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
388, 67, bolt, build, camaro, clean, dyno, hp, ls1tech, make, numbers, rs, sbc, sheet, super, upload
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
