tuning a holley 4150
Ok heres my problem....if it just mash the pedal it like chokes it self kinda like stumbles then takes off....should i buy the accelle pump cams and mess around with them or try something else first?
Normally, I start with the squirter, if you have any kind of motor the factory sq. are too small.
On my 421 we had 42s.
Usually the cams will not need tuning, unless you feel they react too slow, but it normally will be fixed with the sq.
Total timing should be set at whatever RPM you want to have all your timing in it, 3000 RPM is usually a good RPM to set at with a bbc. If it has a stumble when you mash it the secondaries could be not opening right away,or too soon.I would check your timing make sure you got it where you want it then start messing with jets and squirters.
Originally Posted by 1984camaroz28
im also runing a MSD billet mechanicl distrubeter....when timing it is there anything specail like an advance to unhook
Originally Posted by Ls1LikeNoOther
When you set the timing if you have a vacuum advance on the Dist, you always want to disconnect that from the carb.
thanks guys i will doublt check the timing
