Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Compression test
Old 01-03-2006, 11:07 PM
Chevyguy358's Avatar
Default Compression test
I recently had a 383 stroker shortblock built, after running it for about only 50 miles it seemed to be smoking alot of oil. I realize with chromolly rings there should be some smokin during the break in period but this seemed rather excessive. So I did a compression test on each of the cylinders and they all had ratings from 130-150...which i have been told is on the low side. I was wondering what is a good compression rating. All of the plugs looked good except the #8 which was oily. I also found that during the break in period I had an intake leak that was leaking coolant into the oil and I was wondering if this could have kept the rings from seating properly. If not then would you think it to be a bad valve seal... thanks
Old 01-04-2006, 05:27 PM
JTM
JTM's Avatar
I had a similar problem after I got my 383 built, it was smoking alot. Fix was new valve seals, hasn't smoked since.
Old 01-04-2006, 06:35 PM
redbandit98's Avatar
i dont think the compression numbers are that bad..is it smoking at start up or all the time,,.,.did you have the heads redone with new seals etc.?
Old 01-04-2006, 07:23 PM
hondo's Avatar
a leak down test would be best
<---poet
Quick Reply: Compression test
