Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Whats the biggest motor i can put...
Old 02-06-2006, 03:44 PM
markp03's Avatar
Default Whats the biggest motor i can put...
whats the biggest motor you can put in a 2000 camaro?
Old 02-06-2006, 04:10 PM
orange88's Avatar
do you wanna go away from a lsx based motor?
Old 02-06-2006, 04:17 PM
Ace$nyper's Avatar
This is way to broad but the limit is your imangation and wallet.
Sticking with the LSX based motor or not we need to know.
Old 02-06-2006, 05:52 PM
markp03's Avatar
well here is the story i have pt76 gts turbo sitting next to me and i was think if i strap that on i will need to build the motor anyways....so i was think...whats the biggest lsX motor i can fit in there, i hear people turn the ls2 block into a 406 or somthing....I was also wondering if people can make a big block fit in there nice or if thats a huge pain in the rear.
Old 02-06-2006, 05:56 PM
orange88's Avatar
im not to sure of the name of the company that make it but its like a 500inch lsx it has sleves and deck plates. but if it were me id just buy a 6.0 iron and build a 408.
a new iron block is only 600 bucks
Old 02-06-2006, 05:58 PM
orange88's Avatar
here check this out
http://www.w2wpowertrain.com/pc-102-...ort-block.aspx
Old 02-06-2006, 06:08 PM
markp03's Avatar
thats a sweet block... but i was thinkin more like hte 6L iron block like you stated...i would need to buy the block but how much from my ls1 motor could transfer over to the block (like valve train) and i could be totaly wrong here but someone said you could modify the stock crank to work in a 6l to get a 408. or do i need to compleatly but a whole new rotating assembly
Old 02-08-2006, 01:45 PM
PortPros1's Avatar
We build them, depending on the block you want to use you can go up to 428 c.i. with a sleeve kit and a aluminum LS1 block. If you'd like to go over some options give me a call.512-257-0222 ask for Harold.
Old 02-14-2006, 10:50 AM
N20LS1's Avatar
You could fit a 632ci BBC it will fit, but you will have to get a different tranny, rear end, modify the engine bay etc.
Old 02-14-2006, 04:03 PM
Grave's Avatar
I read in the most recent GMHTP that World Products has a 454cid LSX based engine block.
Quick Reply: Whats the biggest motor i can put...
