Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
bulging oil pan?
Old 02-22-2006, 08:46 PM
terr1bleone's Avatar
Default bulging oil pan?
i ran my motor a few weeks ago for the first time just intial fireup and idle for a few seconds, now i went to check up on eveything and it looks like my oil pan is bulging on the bottom? i never heard of this before i wonder what could of caused it and if there is something wrong. it was completely flat when i put it in..almost concaved a little.
Old 02-22-2006, 09:27 PM
jarediocamaro's Avatar
what color is your oil Now?
Old 02-22-2006, 09:36 PM
didnt drain it yet, its brand new didnt see a reason too, if you think it has antifreeze in it, it dosent..i never put any coolant or water in yet.
Old 02-22-2006, 10:32 PM
DeltaT's Avatar
Two possible causes, neither is good: High crankcase pressure (this is what I think is happening) or the pan got struck from the inside (you probably would hear it). Try taking out the dipstick - if you feel air coming from the hole, then it's crankcase pressure.
Jim
Old 02-22-2006, 10:38 PM
if it is crankcase pressure what is the solution to fixing it?
Old 02-23-2006, 02:49 PM
CarelessAndImprudent's Avatar
pcv I think?
Old 02-23-2006, 05:29 PM
nevermind guys, its just a defective pan.
Old 02-26-2006, 05:25 PM
DeltaT's Avatar
What's the defect that caused it to bulge?
Jim
Old 02-27-2006, 01:25 AM
i was told in motors like mine thinnner metal pans do this just fron crank windage
Quick Reply: bulging oil pan?
