Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
383 build with low oil pressure
Old 10-08-2007, 08:11 AM
bigdcustoms's Avatar
Default 383 build with low oil pressure
just built and fired up last week and it has good oil pressure and then the oil pressure keeps droping unil it hits 0 at idle after the motor warms up. I know the problem is probably the bearings but I wanted some input first. It has a high volume mildon m series pump and a 7 quart pan. I dont have a problem pullin the motor and tearin it apart, I just want to make sure that thats what I have to do.
Old 10-08-2007, 10:15 AM
Horsepwraddict's Avatar
are you using an electrical guage? If so throw a mechanical on it to check.
Does it hold good pressure above idle/cruising?
Old 10-08-2007, 10:51 AM
PortPros1's Avatar
Check the oil pressure with a mechanical gauge first, what were your bearing clearances? This type of problem is usually a cracked pickup, an oil plug left out or not installed completely. Did you install the oil plug under the rear main cap?
Old 10-08-2007, 01:16 PM
it has a mechanical gauge on it and it holds pressure while crusing but only for about 15 mins and then it starts to drop...ill have to check those things when we pull the motor this week
Old 10-08-2007, 02:07 PM
Firechikn's Avatar
Pick up too close to the oil pan? But you usually see little to no pressure under rpm. Something to check.
Old 10-08-2007, 02:54 PM
LT1MAN's Avatar
i had similar problem on mine. turns out it was a combination of two things.
1. had a (LT1) camaro pickup and a corvette pan, which put the pickup too close to the pan.
2. engine builder left out front galley plugs, doh!
Old 10-08-2007, 03:30 PM
Jordan S.'s Avatar
What weight oil are you running?
What were the clearances?
Old 10-08-2007, 11:07 PM
im thnkin either the oil plugs or the clearences..unfortunatly we didnt check the clearences but I changed to 20w50 with no luck
Old 10-09-2007, 07:41 AM
CNC BLOCKS N/E's Avatar
Leaving the plug out under the rear main cap will not affect oil pressure once the oil filter is full the oil will just bypass the filter and go the path of least resistance.
I know that is posted in the Chevy power book but its be proven to be a false statement.
Old 10-09-2007, 07:14 PM
ive got a good feeling that the extended oil pickup is not matched to the deep pan.....
Quick Reply: 383 build with low oil pressure
